Shiftindicator light
Started by Belgium R/T -68, October 14, 2009, 06:48:59 AM
Belgium R/T -68
I pressume that the light for the shiftindicator on the tunnelconsole (aut) needs a groundcable. I have one black wire that I suppose are the one for ground there, I connected it to the consolebracket. Whould that be a right assumption? It's from the consoleharness so I don't believe there
is any other options then ground for a black cable there? I checked in the shopmanual but couldn't find it back.
Per
greatwn73
There is no ground wire the light socket is the ground when mounted
Hemidog
Quote from: greatwn73 on October 14, 2009, 10:52:37 PM
Nope, the light housing is plastic, so it doesn't ground.
Yes Per, just ground it to the console brackets.
Belgium R/T -68
Quote from: Hemidog on October 14, 2009, 11:30:33 PM
Thought so, Thanks. :2thumbs: Normally I mark all wire by disassmbly but it must have fallen off.
Per
greatwn73
sorry i thought it was a single lead .
Its not the lead for the 68 only neutral safety switch mounted to the shifter is it?
