Rear suspension hop
Started by G Force, November 26, 2005, 11:11:54 PM
G Force
I added 3 degree shims to the rear suspension in an effort to create  the proper drive line angles and reduce vibration problems.
The vibration is still there and now I also have a "Hop" affect in the rear suspension.
Anyone else ever experience this?? It s hard to believe that a 3 deg. shim can affect the ride dharactoeristics.
are you using coilover shocks ?
What kind of shape are your leaf springs in ?
G Force
The leaf springs are New and seem Ok. The gabriel shocks are also fairly new. I did not have or notice the Hopping before the shims were installed.
Quote from: G Force on November 27, 2005, 12:05:08 PM
Which springs....super stock, hemi replacements ? How many leafs on each side ? Pinion angle will influence spring performance. Ideally you want 5-7* nose down with leaf spring suspension.
Charger4404spd
are the shocks coilovers or just regular shocks ?
coilovers create an ocillation ....or hop
G Force
The shocks are not coil over style. The springs are Mopar Performance ( I do not know the amount of springs but i do know the passenger side has an extra spring). I did not have the hope befroe the 3 deg shims were installed.
I have a gear vender OD unit in the car so Im not sure if the 5-7 deg shims are still proper. I have a pinion snubber that now seems to work properly.
coil overs ALWAYS cause hopping which is why I had to know , next I would try a square top U bolt & clamp the front section of the springs as tight as possible approx 1/2 way between the spring eye & the diff
What is the pinion angle with the shims installed?  The overdrive unit shouldn't be an issue.
G Force
I am not sure what the pinion angle is but I do know that there was no shims in originally. Now the mechanic put in 3 deg. shims.
I thought the overdrive unit causes the drive shaft to get shortened which changes from the stock angles  ???
check the angle , it may not need the shims he added
How much shorter is the driveshaft?
G Force
Quote from: Ghoste on December 05, 2005, 02:47:01 AM
I can only guess its approx. 12" shorter than stock. Im sure that would change the angle,, Right  ???
it will change the angle slightly , it depends how high the rear of the car sits & how much angle the shaft is actually at
G Force
Quote from: Chryco Psycho on December 07, 2005, 01:56:54 AM
New springs from Mopar performance Drivers side has extra leaf (stock)
the U bolts shoild be new try loosening tthem off & removing the shims , see if the problem goes away or gets worse
Steve P.
Ask the shop that shortand your shaft how much they took out or call Gear Vendors. They can tell you the difference.. I don't think it's 12 "s.. That seems like allot.... I don't remember any talk about shims when I spoke to them about doing one in my 65' Coronet....
Steve P.
Holiday, Florida
which leaf springs do you have , possibly the springs are winding up & releasing / snapping straight & causin gthe Hop
Steve P.
G, I would like to know more about your car..
1)  Did you make more changes at the same time as the Gear vendors??
2) Is the cars stance more of a factory car or a 60's FUNNY CAR??
3) Anything different done to the tranny mount while putting in the GV unit??
4) Did GV recommend the 3* shims?
5) Any other changes and mods you have done during or after this mod???
Steve P.
Holiday, Florida
G Force
Quote from: Steve P. on December 10, 2005, 01:53:27 AM
Hi Steve,
1) No additional changes made at the same time the Gear vendors unit was installed.
2) The Cars stance is factory stock with the exception of the 17" after market rims and tires.
3) No changes made to the tranny mount .
4) Gear venders did not reccomend the 3 deg. shims. I had a vibration problem before the gear vendors unit was installed. I thought it was in the drive line so waited till the GV unit was installed  hoping the vibration would go away, It didn't.      I went back to the mechanic that installed the GV unit and asked him to look at the pinion angle, He recomended the 3 Deg. shims. The car now has less vibration with the 3 deg. shims ( still vibrates too much and is not acceptable) But now "Hops"  in the rear.
5)No other changes done during or after the Mod.
NOTE: The leaf springs and shocks are fairly new ( approx. 5,000 miles on them). THere were no shims in the car after the leaf springs were installed ( I do not know if they were there before the springs were changed).
Steve P.
Did your problems start with your rims??  And what rims were on it BEFORE you put the 17s on?
I ask because of unilug problems.. Centering imbalances, heavy wheels, lots of problems can cause wheel hop.. You need to go back and figure out when the problem started and what made the change.. Any chance you still have the old wheels and tires?? Maybe switch back and see if the problem is gone..
Steve P.
Holiday, Florida
BlK03Hemi/70RR
Has the driveshaft been balanced?
1970 Roadrunner
-Matching #'s HP 383
-Auto, 727 Console
-Air Grabber
-EV2 Car; Black Interior
'03 Hemi Ram Single Cab Short Bed
-Stock Performance (For Now)
G Force
Quote from: Steve P. on December 12, 2005, 12:58:53 AM
The Rims and tires are balanced. I had custom cetrifical ceter hubs made so the wheels set on the spindles perfectly centered. alot of the new rims rely on centering  and mounting the wheel with the lugs only.
The wheel  hop started when I put in the 3 Deg. shims.
The drive shaft is new and balanced.
I'd be rechecking the angles then.  With and WITHOUT the shims.
