Adjusting eldebrock 750 need to go back to factory setting
Started by greenpigs, September 02, 2009, 09:53:47 PM
greenpigs
Well I had a badly ground ecu and adjusted my carb lean to try and fix the super rich condition. I now have a good ground on the ecu but a couple plugs the porclin is white. The others are a brownish shade. I put some ngk 4's that are one step hotter than what I was running in. Now I would like to have the carb back to square one before firing it back up.
1969 Charger RT
Living Chevy free
Rolling_Thunder
What did you adjust exactly ?   just the mixture screws ? or did you change metering rods as well ?
greenpigs
1969 Charger RT
Living Chevy free
Turn them in clockwise until they JUST bottom out and then back them off 1-1/2 to 2 turns.
edit-lisiecki is right, they don't need to be jammed home-highlighting added for emphasis  ;)
lisiecki1
Quote from: Ghoste on September 02, 2009, 10:53:23 PM
Turn them in clockwise until they just bottom out and then back them off 1-1/2 to 2 turns.
until they JUST bottom out....don't tweak them.
greenpigs
Sheesh! Only took 1/2 turn to bottom out. I backed out 1.5 turns. One side the spring felt loose. But it was running ok, or seem to.
1969 Charger RT
Living Chevy free
lisiecki1
you can remove the spring and stretch it slightly if you're worried about the preload.  If your engine sees decent vibration it could move your adjustment around if you don't have a preload on it.
