More vacuum leaks
Started by Purple440, August 29, 2009, 03:30:04 PM
Purple440
Hey guys, I had some vacuum leaks between the intake and heads earlier this year and I've since replaced the intake and this time included a gasket on each side of the valley pan to ensure proper sealing.  Well, I've still got this engine shake thing going on (for years now) so I double checked the intake seal today for the hell of it with some carb cleaner, and whad'ya know, I STILL have a vacuum leak on the passenger side, and maybe a small one on the drivers side!  :brickwall: :brickwall:
Anyone had this problem?  Possible warped head?
- Doug
TylerCharger69
Did you use any sealer?    :shruggy:
have the heads or intake been milled?  if not then i use just the valley pan with a good rtv that is oil proof. i prefer ford 7.3 diesel silicone. this stuff is nasty, it seals anything and everything. fuel, oil, water, antifreeze, none of it effects it. i have never had it leak on anything i have ever used it on.
its a bit pricey and only available from the ford dealers.
Purple440
Quote from: TylerCharger69 on August 29, 2009, 07:42:44 PM
Just some adhesive to get the gaskets to stick to the valley pan for installation.  Am I supposed to use sealer along with gaskets?
Ok I just read this thread: http://www.dodgecharger.com/forum/index.php/topic,59292.0.html and it looks like my heads being blueprinted along with the block, it may have changed the geometry of how the intake sits on the head.  Unfortunately I don't know how much they took off to get everything flat.  If they took off enough to cause this, then that may explain why my compression is so high.
I looked on Summit for gasket variations from Edelbrock and it just listed one, which is probably what they sent me with the RPM.  Any suggestions?
Purple440
Quote from: c00nhunterjoe on August 29, 2009, 07:51:29 PM
Just the blueprinting, but I guess that counts.  No milling for compression raising though.
Doug, did you have to elongate the intake bolts to install it ?
Fwiw, i use Ultra copper on both sides of the valley pan and don't use the paper gaskets....let it set up overnight before final torque.
The Felpro 1215 is the 440 intake gasket with the heat crossover block off.  ;)
TylerCharger69
Hmmmmm...I wonder if the block has been decked to the point that the intake sits too high, causing vacuum leaks??? :scratchchin: :scratchchin: :scratchchin:
Purple440
Quote from: firefighter3931 on August 30, 2009, 03:26:33 PM
My builder didn't call me back today, but I don't remember anything about elongated bolts.  Using the same bolts on the RPM as we used on the original M1 dual plane.  Using the 1215 gasket currently based on your recommendations  :yesnod:.
Quote
That's what I'm thinking, or the head work.  My builder said that blueprinting wouldn't take off that much material, but what else would make sealing be so difficult?
- Doug
Purple440
Got a camcorder today for the sole purpose of showing you guys what I'm dealing with.  The vid is 3:26 long, nothing too exciting.  Any thoughts or suggestions are appreciated!
http://www.youtube.com/watch?v=fMUEiYNLpUY
- Doug
[edit] This is extremely slow on youtube - start it and pause it while it loads.  What's up with youtube these days?
all i can say from that is try using ford powerstroke diesel silicone. its only available at ford dealers and is a little pricey, but it is well worth it. this stuff will seal anything and is oil proof. i use it on everything car related and even the house. it works great for patching roof leaks too. its available in standard tubes or caulk gun sticks.
as for the video- you hold more vaccum than i do....lol
Quote from: Purple440 on September 28, 2009, 08:06:39 PM
- Doug
Honestly....that engine idles better than most i've had.  :lol: Have you checked your motor mounts Doug ? That might account for some of the shake ?
GPULLER
Vac looks good to me, way more than my 440 pulls.  The shaking...thought they all shook when you put big hairy man cams in them.
I'm with Ron, check the mounts.  Can you say SOLID MOUNT?
Purple440
Thanks guys.  Yep I'll check the mounts, hadn't considered that because it's not a constant shake even though when I put the camera on the dash it seemed so.  Maybe it is just my cam after all.  I think the vac leaks are gone.
:cheers:
- Doug
