Gear Vendor's overdrive unit for our 727's
Started by hemi68charger, August 26, 2009, 07:28:32 AM
hemi68charger
Hey gang...
Is the Gear Vendor overdrive units nothing more than Chrysler OEM overdrive units on, say my '98 Ram? Or, are they a totally different design to bolt to the back of my 727? I'm wishing to keep the original 4:10's in my Daytona, but want the overdrive capability. I drove the car for the first last weekend on one of our local highways here in Houston and man, it sucked......... Right lane all the time and it's just not right in a Daytona!!!  :icon_smile_big:
Houston Mopar Club Connection
Mick70RR
The overdrives were originally made by Laycock here in England. GKN later took over production until recently when Gear Vendors bought all remaining stock and tooling. The Gear Vendors version is much stronger than the original overdrives and will handle at least 1200hp.
I have one behind my 4 speed and run 3.91 gears, 70mph = 2600rpm.
1970 Road Runner, 505 cid, 4 speed, GV overdrive, 3.91 gears
11.98 @ 117 on street treads
gordo1968charger
i m running 4:10s and with the overdrive on its more or less the same as the 3:23 i was running previous to that. :2thumbs:
68 charger+4 kids=2 jobs
Rolling_Thunder
they are different units that bolt in place of your original tail shaft of your 727...      :2thumbs:
hemi68charger
Quote from: gordo1968charger on August 26, 2009, 11:42:46 AM
You have a Gear Vendor unit?
The final ratio with 4.10's and a GV is 3.20
mauve66
i had to ",massage" the trans tunnell of my 1st gen a little bit, are you sure you want to do that to your PERFECT LOOKING car???
oh yeah, yes they are different
some liek them. some hate them.  i haven't gotten to try mine yet and its going on 7 years now.........................................
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
RECHRGD
I've got one on my car.  With 3.55's, I believe my final ratio comes out at about 2.76.  I like the unit, but have had vibration problems that I've been trying to sort out every sense I installed it.  It has to do with getting the pinion angle just right.  Bob
13.53 @ 105.32
mauve66
not to hijack, but you STILL haven't gotten rid of that vibration??  hadn't seen any updates
NEEDS:
body work
total wiring
PW
PDLKS
Tint
trim
alignment
RECHRGD
Quote from: mauve66 on August 26, 2009, 06:19:25 PM
NO!!  The last thing that I did was take off the schumaker engine and tranny mounts and replaced them with stock units.  That  made the problem much less noticable, but it's still there.  None of the pinion angle settings stopped it.  Going against conventional wisdom, my dyno guy had the same problem with a bad ass challenger that he was building for some guy.  He cured it by putting the pig in a 6 degree nose down position.  That will be my next attempt to cure this thing.   Bob
13.53 @ 105.32
472 R/T SE
Ah yes, the Gear Vibration overdrive.  I noticed the vibration right away too.  Also a clutch burning smell.  Never did figure that out.
Let me know if you decide to get one Troy.  There's a guy down in Oregon that discounts them, Bob & Ranger Max & don't know who else have went through him.  Dealers' aren't suppose to discount, like TTI.  I talked to him at the Roadster Show & he said he'd also do a group buy on them.
My car required zero tunnel persuasion.  Only problem was the speedo adapter they sent was wrong.
I'm still running .55's but am gonna put my new Power Lock .91's in to take advantage of it.
Best mod so far.
68X426
Troy: I can add that the GV is a must have from my experience (limited as it is). Life in the right lane is not worth living. The OD gets 4.10 down to 3.20 and into the fast lane.
It's only good vibrations in my 660hp Hemi RR.  :yesnod:  It's 600 miles new but there are no issues with vibrations. Have not done any quarters yet.
It is programmed to kick in at 48 mph (pre-set at factory?), and I find that when I jump hard on the gas it will hit OD at 42 or so. I can then feather the pedal and cruise at 30mph at only 1300 rpm. On the highway it's 2700 rpm at 70 and easy to have a conversation.
Best of all: highway mileage is 13.8 ! Granted, just 2 trips of 120 miles each. But that's from a 660 hp Hemi and 4.10s, all thanks to the GV. Best bang for the buck there is.
I'm not tech enough to know the "why for's", but the tech guys say the unit is completely bomb-proof and will outlast everything else on the car.
Hope you can hook one up, Dan.
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
gordo1968charger
Quote from: hemi68charger on August 26, 2009, 02:04:10 PM
yes,treat myself back in xmas 2007,wife still does nt know :2thumbs:
i put a post on here regarding keisler overdrive versus gear vendors,mr angry swears by his and he does about 30000 miles a year with his unit.
the hardest part of fitting was getting the old tail unit off,wiring was straight forward and i ve had no issues at all.
year one sent me the wrong coupler and i had to wait a few weeks for them to sort it out but it was during the winter so it did nt bother me too much.
mauve66
oh yeah, my old version had a straight on adaptor for the speedo at the trans, the tunnel on a 1st gen is so tight i had to get them to send me a 90 degree adapter, don't know if its standard on the kit now or not
NEEDS:
body work
total wiring
PW
PDLKS
Tint
trim
alignment
