68 Charger Dash Light Problem
Started by BronzeOnSteelies, August 23, 2009, 01:37:52 PM
BronzeOnSteelies
I have noticed that with my dash lights on, the wad of wires that come out of the dash light dial switch are getting real hot. Also if I wiggle the bundle of wires the dash lights sometime go on and off.
The switch is my 2nd one. I bought it used. With the switch dialed down to off there is no heat in the wires.
Before I had this switch I had bypassed the switch and had the gauge lights on all the time. I forgot how I did this.
Is this likely the switch? The dimmer function works.
If I could bypass the switch again I could see if the wires still heat up.
Any suggestions/knowledge are welcome
Mark       :shruggy:
68 MM1 (Turbine Bronze) R/T
If it's like my 70's it dims and just past high (dim) it has a "bump" that turns on the dome light also.(if I remember right the bump feeds a ground) I ran with mine jumped for years.
nascarxx29
I changed out the bulbs from original 158 s to 194 .And bypassed the roll switch .You never need to lower dash lights
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
