frozen wheels
Started by Foreman72, August 19, 2009, 01:19:02 PM
Foreman72
so i need my 72 to roll in order to get it where i need it...(obviously :lol:)
i got one of the rear wheels (drum brakes) to spin but the other one won't budge...
i haven't looked at the front (discs) yet but i'm sure it'll be as bad...
any thoughts on how to free these up? take them off and remove the drums? anything? :shruggy:
thanks
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
gasoline_24
Have you disconnected your e brake?  I would guess it is rusted and will not release.
Foreman72
Quote from: gasoline_24 on August 19, 2009, 03:25:05 PM
would that cause only one side to turn? i could try...thanks
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
gasoline_24
There should be a seperate cable running to each side.  If only one side is hanging I would try to pull the drum if you can.  It may not come free if the brake is locked up.  If you don't care about the cable just cut it where it enters through the dust shield.
ipstrategies
My back wheel was frozen when I got my Charger. Mine rolled up the trailer fine but froze up backing it off I used a floor jack to get it off trailer and took the wheel off, I had to hit the edge of drum from backside,  the first official work on my Charger involved a large hammer.. luckily that has been the only time I have used that hammer on my car.
1971 Dodge Charger SE 383 Magnum
1999 Dodge Durango 5.9
1995 Chrysler LHS
