brake fluid pressure at pressure check switch ?
Started by Nacho-RT74, August 04, 2009, 11:16:08 PM
aren't both ( front and rear ) sistem isolated from each other and just linked by the double action piston inside the dist block ?
if is in that way, how I can get some pressure on switch location, enough to have a leak there ?
Dist block/prop valve is new ( 2 or 3  years old really )... this unit:
what BTW I noticed is nothing like the original inside like does look perfect exact unit outside!!! switch and related system does look TOTALLY diff inside.
