cant advance my timing any more :( need a suggestion
Started by 68chargerboy, July 18, 2009, 12:10:49 AM
68chargerboy
hi, so today i was dialing in the timing in my 440 and when i was turning the distributor the vacuum advance can is now touching the radiator hose and i can not go any further  ::)  so what can i do so that i can keep advancing the timing without the hassel of buying a new thermostat housing? thanks
Zach
The70RT
Something you may not wanna do -Pull the distributor out and turn it back a tooth or two and then do the same with the wires. The question is why can't you adjust it normally? Did you change your cam, chain & gears?
68chargerboy
what do you mean "why cant i do it the normal way"? i thought that the only way to adjust timing is to rotate the distributor clock wise or counter clockwise? is there a diffrent way that i do not know about?
y3chargerrt
The immediate shaft needs to be installed correctly for the distributor to be in the proper place. At TDC mark the rotor and distributor positon then pull it out. The slot of the shaft should be horizontal with you look at it through the hole.
You may just rotate your plug wires one hole over on the cap....what he means is with everything proper nothing should have to be done, it should be where it needs to be. I don't know why but when I changed out from a rebuilt dist. to a new MoPar dist. I had to move the wires over one hole to get it positioned where I needed it to adjust time. I checked and the rotor lines up different to the tab on the bottom of the dist. shaft between the 2 dist. so just move your wires over one hole, it worked for me.
The70RT
Quote from: b5blue on July 18, 2009, 09:29:30 AM
Thanks for clarifying what I was stating.
68chargerboy
ohhh i understand now.  thanks alot for the help guys.  if its not one problem its another finally working out all the kinks now that im driving it again  ;)
