which way does it plug in
Started by Lee A, July 13, 2009, 09:50:07 PM
Lee A
On a 68 charger which way does the hazard plug go in it is square and can go two differnet ways one side has a hump in the middle I don't know because when i took the dash apart wasnt hooked up
1968 Dodge Charger 440
1969 Dodge Charger 383
TylerCharger69
Are you talking about the flasher relay??? :shruggy:
Rolling_Thunder
If you are talking about the emergency flasher switch on the dash - then the correct answer is that it can go on either way - the switch is a DPST so either way will work
