rallye dash
Started by westcoastdodge, July 07, 2009, 03:36:46 PM
westcoastdodge
hey guys what is the little red warning lamp on the speedometer for?? ignition warning or high beam  :shruggy:
I don't care what is is designed to do,I want to know what it can do.
Gene Kranz
lisiecki1
should be ignition, or charge, i believe the high beam indicator is blue.....
y3chargerrt
On 69s the red light is hi beams.
lisiecki1
westcoastdodge
so no charge warning lamp at all then,68 rt btw
Gene Kranz
Quote from: ray on July 07, 2009, 05:03:10 PM
nope
..was thinking of fitting one , as i have converted the Amp to a volt gauge   would like a instant warning like that of a warning lamp if i lose a belt at speed .
but   not sure where the wires run to , trying to think what late model has one that i can look at the wiring diagram   :scope:  :popcrn:
high beams indicator... turned blue since 73 or 74
non idiot charge warning lamp, you got ammeter instead.
