Spark Plugs
Started by BBKNARF, July 05, 2009, 10:26:43 AM
BBKNARF
Why doe's my car slightly hesitates @ low rpm  :shruggy: It was running fine until I changed the plugs I was running NGK V-Power FR4 stock #5188, some guy told me I should run the NGK BCP7ES stock #5030
the performane will be better, but it's not. I'm running a stroker 451, 10.6.1 comp., Edelbrock performer rpm heads and intake (dual plane), Holley 950 cfm D.P., Comp cams roller mechanical, I evin bumped up the jet size from 79 to 82 primary, and 82 to 85 secondary, after checking the plugs after 40 miles they are a very light tan in color,  my total timing advance is @ 36 and it still did'nt help why ? I think I should put back the old plugs in.
68 Charger, slowly in the works, 451 c.i. approx. 535 hp @ the flywheel, so far best time in the 1/4
11.21 @ 119 mph, full exhaust, stock suspension, 4:10s @ 3640 pounds.
