Kickdown help
Started by paulgrr63, June 27, 2009, 11:03:09 PM
paulgrr63
I installed a 4bbl Holley 570 carb on my 318(originally 2bbl). I bought Holley p/n 20-7 and 20-36 since the manual said I would need it for a Chrysler application. http://www.summitracing.com/parts/HLY-20-7/ and http://www.summitracing.com/parts/HLY-20-36/ The kickdown doesn't seem right. Does anyone have a pic of the kickdown linkage on a 4bbl carb? I drove it around and it wasn't shifting correctly. Any help would be appreciated. Paul
mikepmcs
You are on the right track 2bbl and 4bbl throttle linkage(kickdown) are different.  You can modify it and make it longer by putting a threaded barrel nut in between two threaded rods to extend it.  You don't want to be driving it around like that because it will ruin your tranny if the linkage isn't adjusted correctly.
I'd put the 2bbl back on until you get the correct linkage or modify it. :Twocents:
mikepmcs
paulgrr63
Quote from: mikepmcs on June 27, 2009, 11:07:49 PM
It is going to be sitting in my garage until i get it right :yesnod: Thanks for your help :cheers:
GreenMachine
   Here's a SB 4 bbl. setup on Ebay. The bracket in the center is the 4 bbl. bracket that bolts to the intake. If you look at yours, you will see the difference. He has 2 upper rods, one is adjustable, the other is not. They both should work for a 4 bbl.. It looks like the rod below the intake bracket attached to the bellcrank is from a big block, but the rod at the very top of the pic is for a small block.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=140329828947&viewitem=&sspagename=STRK%3AMEWAX%3AIT
tricky lugnuts
Not trying to be the salesman, but I've got a four barrel kickdown setup for a small block/727 if you want it. Worked in my Charger with a 340/727 and Carter AFB. It's all stock stuff and should be everything you need. Price is highly negotiable. The stuff is just sitting in my closet and taking up space.
Just let me know if you want it. I've moved on to a 440 setup. I can send you a picture if you want -
Tom
maxwellwedge
He probably needs the 1 piece kickdown linkage.
tricky lugnuts
That's what I've got. Sorry, forgot to specify - 71-74 Charger...
