new 607 CID engine now running
Started by LUMI, May 20, 2009, 02:57:43 PM
LUMI
motorplate would have be better/easier but maybe in the future...
those schumacher hemi motormounts seems to be quite stiff and i allready bought those :flame:
i cant understand why wedge block has hemi mounts :rotz:
LUMI
more broblems  :flame:
flexplate and converter wont bolt in together there will be 1/6" space between them
is it OK to weld shims to the converter
i see no other option
converter is TCI´s PRO-X 727 143012 9" W150+
maxwellwedge
Hard to tell but it looks like the flex plate is backwards. The crank bolts look like they are causing the gap.     :scratchchin:
LUMI
Quote from: maxwellwedge on July 31, 2011, 09:48:13 AM
Hard to tell but it looks like the flex plate is backwards. The crank bolts look like it is causing the gap.
well on the flexplate there was a engine side marked so i put it on that  :2thumbs:
crank is Callies 8 bolt with arp bolts
maxwellwedge
It still doesn't look right......Are those crank bolts resting against the convertor?
LUMI
yes they are
and you cant turn the flexplate without enlarging few holes so it´s not an option :flame:
yeah that would of been my first guess too :yesnod: :scratchchin:
LUMI
ill try to find if there is an bolt on flexplate to this setup
now i have SFI A736421 plate
or i weld those shims to converter :nana:
gtx6970
flex plate is in right.
I dare say you need a different convertor.
Torque convertor can not rest on flexplate to crank bolts . There has to be room for the torque to expand to a certain degree
me persoanlly would not weld anthing to the convertor lugs - you going to have to have an area that is not threaded , leaving very little of the bolt threaded into the convertor - thus causing a  weak link in the powertrain
LUMI
but it is a convertor for tf727 ??
i checket it to my old engine which has 6 bolt crank it even wont bolt on that, both have same style flexplates :RantExplode:
if the flexplate would be straight it would fit, is there that kind of flexplates available?
well i sended email to TCI lets see it they reply :o
LUMI
now with a new converter
and still so far from running :brickwall:
CSR supershield wont fit with original trasnsmount so i have to modify it or hammer the trans tunnel :2thumbs:
well maybe next week
67440chrg
Good luck with the rest of your build. Your car looks great and should be a street monster.
good you got the converter /flexplate  deal sorted  ,  looking forward to seeing more progress pictures as an when  :yesnod: :coolgleamA: :cheers: :popcrn:
FJMG
Wow what a great car, I'm sure you'll get everything straightened out. Did Koffel's actually ship you an engine with oil lines directly in front of the Hemi mount boss? I cannot believe that anyone would send out a motor that cannot utilize the mounting area on the engine block without some letting the prospective buyer know!
Looking forward to your next update!
LUMI
Quote from: FJMG on September 05, 2011, 09:18:03 PM
no this engine was bought used from Holland, it has had 4 low test runs and 8 full passes on a strip, the privious owner wanted to go to the 7´s, on this engine he got mid/high 8´s with tube chassis belvedere
Charger´69
Plymouth Fury "Christine's Sister" 4x4 6-71 1959
Dodge Charger R/T 440cid 1969
Pontiac Trans Am T-top SuperBandit 400cid 1978
Jeep Cherokee Renegade 4x4 3.7 2006
FLG
Looks awesome.
Is that air cleaner top also filtered? If not im willing to guess your going to choke her out at higher RPM's, its a bit small for such a big motor (unless top is filitered as well)
LUMI
Quote from: Charger´69 on January 30, 2012, 04:29:18 AM
So, when this beast is ready..?  :scratchchin:
been having some broblems  (=my alcohol broblem :2thumbs:) and havent been in my garage for 2 mounths, but hopefully next summer :angel:
Quote from: FLG on January 30, 2012, 04:40:07 AM
Looks awesome.
yes it is, and it need more that that 2" filter for sure
LUMI
got it running today :cheers:
runs nicely at 800rpm
still some broblems, distributor is locked so it wont start when hot, need to make a switch between msd6 small red wire so i can start it first and hit the ignition after that
shifter cable needs to be adjusted did not find neutral at all with that Hurst Promatic2 shifter
and my new fiberglass hood should be ready in a week
Quote from: LUMI on May 09, 2012, 02:11:16 PM
:coolgleamA:  ....... :popcrn:
TUFCAT
Quote from: LUMI on February 01, 2012, 10:23:00 AM
Shoot that's nothin, we all have that excuse.  :cheers:
Bob T
Monster of a car Lumi , man you've had some probs getting it sorted
Hope its on the home stretch now
A buddy of mine has an Indy 605 in a 72 RoadRunner, crazy fast on the road, has done an 11.3 on street tyres, I had a drive of it a few months back,  ;) its comes on real quick.  pretty damn cool
:cheers:
Old Dog, Old Tricks.
MoPar_440
LUMI, your car is awesome!!!!!  :drool5: :drool5: :drool5: :drool5:
Looks like all your hard work is paying off, almost there mate!!!
Phhhhwwoooaarrrrr so TUFFFF!!!!! :cheers: :yesnod: :yesnod: :yesnod:
1968 Dodge Charger, all numbers matching 383 BB, factory air, 727, PP1 red, Black vinyl roof, black interior, Magnum 500 wheels..yes i have Dodge fever.... There's only one cure...CHARGER!!!!
Mopar....No replacement for displacement!!!
hatersaurusrex
Quote from: Foreman72 on May 20, 2009, 04:11:16 PM
these are the things i see that are different :Twocents: :Twocents:
Don't forget the tires, not like big plumpies like that are cheap to replace.
Not likely someone who stole such a high profile car (with a prominent magazine spread several years back) would go to all the trouble of replacing the axle, exhaust, tires, coilovers, etc and try to sell it without at least a crappy repaint.
[ŌŌ]ƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖƖ[ŌŌ] = 68
[ŌŌ][ƖƖƖƖƖƖƖƖƖƖƖ][ƖƖƖƖƖƖƖƖƖƖƖ][ŌŌ] = 69
(ŌŌ)[ƗƗƗƗƗƗƗƗƗƗƗƗƗƗƗƗƗƗ](ŌŌ) = 70
LUMI
Now it runs :cheers:
didnt get it running good on 1050 3 circuit Dominator, it was pig rich on part throttle
but got custom build 1150 AED Max Pro Dominator last week and it runs smooth with it :coolgleamA:
