New trunk seal problem
Started by flyinlow, May 13, 2009, 06:42:48 PM
flyinlow
After painting i installed a new trunk seal on my 73. Now I can barely close the trunk . Had to adjust the latch to close . Will this seal compress soon?
Bob
Does it line up and flush all the way around?
Bob
Rallye
I have the same problem on my 72.  Just put on a new seal, trunk closes, but very tight and sitting a bit too high.  I've adjusted the latch to bring the lid as far down as it will go, but still sits too high.  I'm keeping the trunk closed for a few days to see if it will compress on its own.  If anyone has any other suggestions, please let us know...
1972 Charger Rallye - 400magnum
Hemidog
let it sit in the sun with the lid closed for a while.
flyinlow
Yea , seal installed evenly . I will try setting in the sun, my kind of fix.
bordin34
I installed my, incorrect, seal over a year ago and it still hasn't compressed enough to line up the gaps. If you have the incorrect one it may take a long time to compress enough so there is no gap
1967 Coronet Black 440 Auto
Mahwah,NJ
Bob
Quote from: flyinlow on May 14, 2009, 02:53:54 PM
I installed mine over a year ago and did not have any problem. It did shut a little tighter but when new it is suppose to shut a little tighter. It did not throw the alignment at all. Hmm. :scratchchin:
flyinlow
Went to the Chrysler classic spring event yeasterday. looked at 2 other 3rd gens. they sent the wrong seal. Too tall.
Rocpor was there and I talked to them abou the seal   They said they have used that seal with good results.
The seal that looks right and was on the 3rd gens I looked at was listed for E bodys.
I am going to cut the seal that is on there with a scalpal and see if I can make it work for now.  :brickwall:  I thought I was all set for an other 36 years.
mikepmcs
Quote from: flyinlow on May 16, 2009, 09:16:34 AM
:lol:
I giggled a little.
another solution, could it be bend down a little bit the lip where seal goes... I did it myself
