727 Speedo Gear
Started by Lee A, May 06, 2009, 07:37:38 PM
Lee A
Where can I find a speedo gear that has 34 teeth on it to make my speedometer the right speed
1968 Dodge Charger 440
1969 Dodge Charger 383
From your friendly Dodge dealer.
62 Max
Wow, they've gone up a hell of a lot then since the last time I bought one.
ebay had tem on $35 rate
greenpigs
try year one or mancinis
1969 Charger RT
Living Chevy free
terrible one
Go with Ebay, you'll usually find them in lots (used) where they let you choose the one you need after you buy. Find out the teeth you need then search Ebay motors. I got the one I needed for $16 plus shipping.
motoreese
I have a 69 Dodge Charger and I put new tires on it now my speedometer is off. Im kinda OCD about little things like that.
Its only like 5mph at 65 but id still like to fix it. Anyone know what size gear comes stock and what size I need to go to?
Thank you fellas!
JamieZ
Depends on tire size and rear end ratio.  This chart gets posted on a lot of Mopar forums:
Quote from: motoreese on February 02, 2014, 09:03:42 PM
Thank you fellas!
5mph off which way? If your speedo is reading faster, then you need a one tooth larger speedo gear to slow it down.
If it's reading slower, you need a smaller gear...
you will need to know what gear you have in there now by looking at it and go from there
randy73
PATC in La. has them, I got one for $35+
I bought mine off ebay, the guy had tons of them for less than $20 if I remember.  I'll try to find it but it's been a while.
