1974 Suspension Parts
Started by Skinypete, May 05, 2009, 12:32:15 PM
Skinypete
Where can I find new suspension parts for my 74 Charger?  I'm looking to support a 440.
DJMIII
mmm lot of options but some are limited.
T bars: Firm feel
Shocks: just Monroe-Matic or KYB GR2s... however Firmfeel could supply them... dunno if they offer another option
Firm feel is a good suplier of everything for 74, specially if you think on get new T bars and Sway bar. Not too much suppliers for those to 73 and laters models
Summit too for the rest
PST suspension have lot, talking about isolation, bushings, ball joints etc...
on rear... dunno about springs, but there is somebody offering the spring isolators for iso clamps assembly kind.
HiPo shocks for rear are available because they are the same for earliers too
bordin34
This should be everything you need except T-Bars. I do not know however if the C-body tie-rods and stuff will fit. Your ball joints may or may not be threaded, you also can choose if you want to replace your bump stops. Some people also opt for the problem solver bushings to get a better alignment.
2-Tie-Rod Adjusting Sleeve Moog ES440S C-Body Part
2-Inner Tie-Rod End Spicer 4011049 C-Body
2-Outer Tie-Rod End Spicer 4011047 C-Body
2-Upper Ball Joints Moog K7262N Threaded
2-Lower Ball Joints Moog K719 Threaded
1-Pitman Arm Spicer 4501028
1-Idler Arm Spicer 4501032
2-LCA Bushings Spicer 5651028 Rubber
1967 Coronet Black 440 Auto
Mahwah,NJ
74 lowers BJ are originially pressed
