Fusible link
Started by GN, April 25, 2009, 06:13:44 PM
GN
Does the fusible link run from the firewall j-box to the starter relay as one piece? Does it just pull out from the firewall box? Can someone please post a picture? Thanks.
Fuseable link goes from the bulkhead connector to the starter relay...all 1 piece
Unless it's blown, then it might be 2 pieces
LOL
well on 3rd gens is two pieces, if we can say so... the fuse link won't go directly to plug at bulkhead, will plug on a red wire of forward ligthning harness with a bullet kind terminal instead, then the red wire goes to firewall plug
GN
Nacho,
Do you know where I can get a replacement or can I splice in one using bullet connecters? Thanls.
that pic is from year one PN FD5283, They have it. Mostly sure other vendors will have it too.
