505 Stroker build
Started by dstryr, April 15, 2009, 12:51:32 PM
dstryr
505 Cubic Inch 6BBL
598hp  651ft lb torque
How 'bout one thread for all of my questions instead of a new thread each time? ;)
Here are the basics:
1966 440 block  +.030"
440 Source 512" kit
440 Source heads, valve job, back-cut valves
Porting:  254cfm initial, 283 after porting on the intake side
.044" ROL head gasket
Squared and decked, pistons -.004"
10.2:1 compr. approx.
Comp Cams  XS290S
Comp Cams EDM lifters
Smith Bros Pushrods
Harland Sharp 1.5  roller rockers S70015K
'69 6 bbl induction system with Promax outboard metering plates, center metering block, and rear adj. base
Stock dist. with Pertronix Ignitor conversion and Flamethrower coil
Doug's D452 2" headers
Here's my question for the day;
My builder has mocked up the block to prep for zero decking.  Left side he says the pistons run  -.016 to -.017 but the right side is -.018, -.017, -.010, -.014.  Does that sound like a rod needs correcting?  The plan is to zero deck the block and run the .044 ROL gasket for quench.
Thanks!
dstryr, since 1986.
Bill of Rights
Frank, my own block was waay out of whack ; one bank taller than the other and both banks were uneven corner to corner. Not an uncommon occurance with mopar  :P
It's also possible that the crank indexing might need to be corrected....that often happens with aftermarket "budget" cranks.  :yesnod:
dstryr
If the crank indexing was off then would I expect to see both pistons on that journal higher than the rest?  Is a 'long' rod a possibility?  What's an acceptable variation in piston heights?
The machine shop owner came well-recommended by a friend but his hey-day was the 70's and 80's and he's not so much into the 'new' stuff that is available for mopars.  So he's is asking me what I want to do because he's not real comfortable with the .040 quench distance and is afraid there could be contact if the piston rocks a little.  He told me yesterday the bores were honed to the 440Source specs is for clearance but I didn't ask what the clearances were.
He is super-particular and wants to do it right so there are no issues for me in the future so for now I'll have to ask a few  :icon_smile_question: :icon_smile_question: so I am comfortable sorting this out with him.
dstryr, since 1986.
Bill of Rights
Sure, it's possible that the rod lengths are off....he'll need to mic them out to see what you've got.  :yesnod:
He should be able to tell you how far the block is out of whack as well....as of now it hasn't been machined, correct ? Most of the problem should be solved once the block is squared up. If you don't want to have the crank indexed then have him set the deckheight so that the tallest piston is at zero deck. A few thousandths difference won't make any difference.
The .044 quench is fine....with a shorter piston and larger diameter bore there might be more piston rock but even at that .040 is safe, inmo. I've read of .030-.035 tight quench builds without issue but that's a little too tight for my comfort level.  ;)
dstryr
Thanks, Ron
No, the block hasn't been cut yet.  He will cut each side .010" and the tall piston will be at deck height and the rest will be just a little down, -.004 to -.008.   He should have it assembled by the end of next week. :D
dstryr, since 1986.
Bill of Rights
Quote from: dstryr on April 17, 2009, 02:45:11 PM
Right On !  :2thumbs:
dstryr
Hoping to get an exhaust system figured out for this car.  I have Doug's D452 2" headers and was thinking of going with 3" to the Ultrflows and then 2-1/2 out the back using stock chrome tips.  Will 2-1/2" tailpipes flow well enough for this big of a motor?  I won't be going to the track much and with the HP, I don't expect to need to turn big RPMs.
dstryr, since 1986.
Bill of Rights
The exhaust gases cool the further away from the collecter they get so on a street build that will be "all done" by 6k.... i would have no problem using a 2.5in tailpipe.  :2thumbs:
On that note i would opt for a 3in muffler and reduce it at the tailpipe joint.  ;)
dstryr
My guy is assembling the motor and called this morning with a problem.  He says the crankshaft mics out at 1.5632" and the cam sprocket mics out at 1.5660".  He says it should be press fit and spins freely.  The crank is from 440Source and cam set is a CompCams adjustable, p/n is at home.
Any comments on this? :scratchchin:
dstryr, since 1986.
Bill of Rights
Frank, i'm sure you're referencing the lower gear on the timing set correct....not the upper cam gear ?
The keyway will keep the lower gear properly oriented and when you install the Dampner it will push the lower gear in tight and keep it from walking around. None of the lower gears i've installed were press fit....they slid on easily.
dstryr
That's it, Ron.  I mis-spoke.   I think you are you saying the damper will also sandwich the lower gear to the shoulder on the snout so that the key is not what keeps the sprocket in place, correct?
This is the first 440 stroker he's built and I have so far supplied the parts except for the pushrods.  Should have the measurement today to order some Smith Bros. rods.
I was just thinking, since I have been supplying the parts and the block was align honed, I may need an under-sized timing chaing.  I ordered the cam, lifters, and timing set from Dwayne Porter but am pretty certain we didn't choose an undersize chain.
dstryr, since 1986.
Bill of Rights
Frank, the key keeps the lower gear from spinning on the crank but the dampner also helps to secure it as well.  :yesnod:
You'll have to test fit the timing set to see if there is any slop in the chain. It depends how much material was removed during the align hone.
Good choice on the parts supplier....you would be hard pressed to find someone more knowledgable than Dwayne.  :2thumbs:
dstryr
Ok, :2thumbs: my builder hasn't used aftermarket mopar cranks and thought this was just sloppy work and said, "Call the guy you got it from!" so I gave 440Source a call and asked the crank spec, 1.5632-1.564.  Mine is 1.5632 as measured by the builder.  Then I called Dwayne Porter because I bought the cam, rockers, and timing set from him and he told me that since there are several aftermarket crank manufacturers out there with varying degrees of QC that the sprockets are typically a little on the loose side, probably on purpose to take into account the variations from different crankshafts.  He also said he has often seen .003-.004 clearance, while mine is only about .0028".  Builder is OK with that.   Assembly continues...
dstryr, since 1986.
Bill of Rights
See...no worries !  :icon_smile_big: Oddly enough, I happened to be visiting Dwayne at the shop and was there when you called....talk about timing.  :lol:
Like i told you Frank the last few set's i've installed have not been press fit and slid on without any difficulty. None of those engines have had any issues and one of them is a supercharged 440 with a solid roller cam and 600lb spring pressures.  :yesnod:
Keep us up to speed on your progress  :2thumbs:
dstryr
Hope to get few questions answered on pushrods with the Harland-Sharps.
1)What size, 5/16" or 3/8" with stock Stealth springs and the solid lifter cam.
2)Has anyone had clearance issues with pushrods in general?  My builder thinks there will be interference.
3)Would adjustable pushrods be a better choice for the future in case I decide to cut the heads for a little more compression?
The XS290S cam is recommended for 10.5:1 and I figured at zero deck the comp. would be 10.3:1 and I could get away with that.  With the 'tall' piston from my earlier question the deck was cut on both sides 0.010 so the tall piston is at zero and the rest about .004 to .008 in the hole.  I figured that would be just over 10.1:1 and maybe that cam might like a little more squeeze down the road.
dstryr, since 1986.
Bill of Rights
Frank, the 5/16 heavy wall (.065) chrome moly pushrods should work fine...that's what i have in mine.  ;)
With a 1.5 rocker arm and the 5/16 pushrods it should clear without issue I would think ? Problems usually arise when thicker pushrods and increased rocker ratios are employed.  :yesnod:
I wouldn't worry about bumping up the compression....that cam is small enough in a 500in build that it will make tons of power down low. Those recommendations you're reading pertain to a 440....the extra stroke will tame the cam down considerably and make it act "smaller" than it would in a 440 based build. That puppy is going to be a torque monster with very good street manners.  :icon_smile_big:
dstryr
dstryr, since 1986.
Bill of Rights
dstryr
I think this build will finally be done after just ONE part arrives.  The 440Source pickup with the collar interferes with a rod.  440Source says take a belt sander to it and clearance it, but don't go too crazy or it will window the collar-not good.  So I said screw it and ordered a 3/8" stroker pickup w/out the collar for my 7" deep pan and should have it by Monday.
Just a word of advice, use the pickup tube without the collar for a stroked motor. :icon_smile_blackeye:
dstryr, since 1986.
Bill of Rights
Sounds like you're getting very close to firing that beast up Frank !  :icon_smile_big:
Minor setback on the rod/pickup clearance...thanks for the heads-up  ;)
I've had good luck with the hemi pan and matching pickup....knock on wood.  :icon_smile_cool:
dstryr
dstryr, since 1986.
Bill of Rights
dstryr
Have gotten a little side-tracked since Carlisle, then all the small details like water pumps and housings had to be settled, so still working on getting this motor completed.  I think Musicman and I may just have to be happy to see our motors in and running by spring to start next year's cruise season, but I'm still hoping I have a week or two to fry some tires if I can get it broken in this fall.  Musicman, I hope you get to yours as well.
Question on a tight new motor...
I have put oil in and primed the motor and gotten plenty of oil to both rocker shafts.  The motor takes a lot of effort to turn.  This may be a subjective question, but how tight is too tight?  I used my torque wrench and was in the 80ft/lbs range, plugs finger tight in the holes and intake and exhaust manifolds taped over to keep dust out, but I don't see those two things as culprits.
dstryr, since 1986.
Bill of Rights
dstryr
bump before it goes to page 2... :o
dstryr, since 1986.
Bill of Rights
Quote from: dstryr on October 17, 2009, 06:07:34 PM
Frank, is the cam installed along with the valvetrain ? If so, that will make it harder to turn over, especially with the plugs installed  :yesnod:
I like to see 20-25ftlbs on the assembled shortblock with no heads or valvetrain.
Musicman
Hi Frank
It's good to hear that you are nearing the finish line  :2thumbs:
As Ron has already stated... if you have everything installed, it is going to turn over rather hard due to cylinder compression, valve spring pressures, etc,etc,etc. Pull the plugs and try it again, I think you'll find it rolls over much easier :yesnod:  It's not going to freewheel of course, due to valve train pressures etc., but it should roll over much easier.
Keep us posted :popcrn:
Mike :cheers:
dstryr
The motor went to the shop on Friday and will be broken in this week.  Next week is dyno time, barring any issues popping up. :2thumbs:
dstryr, since 1986.
Bill of Rights
