New members Restoration, 69 RT/SE
Started by roger440, March 29, 2009, 02:39:38 PM
Dan T
You should be very proud of your work!!
It looks stunning..
I'm going to have to re-finance my house to get body & paint like that on my Charger!!
Keep it up!!
1969 Charger R/T
1969 Dart Custom
2006 Charger R/T
roger440
Thought it was time for a bit of an update :)
As the workshop is a bit small, ive had to move the shell into a position that i cant work on it and covered it up so that i have created a working area to restore all the parts that need to go back on.
With the shell safely out of the way, ive started on all the parts. As everything needs restoring in some way or other, i though id best make sure these things are the right color! Any one who see something wrong in the pics, please do say.
Lots of bits went to the powder coater, but he did one thing wrong. He did the rear springs in black, not silver. I know some springs were black, but could mine have been black???????????? Car was scheduled for build 2nd september 1968. Any thoughts?
Also, battery tray, should it be black or body color?
Ive done lots of small parts but most of these are all bagged up so no pics :(
Anyway, here are some pics of some of the bits so far.
1969 Dodge Charger RT/SE
1970 Plymouth Roadrunner - SOLD
2017 HSV Maloo
2003 Holden SS Ute
1970 Triumph 2000 Estate, fitted Rover V8
1961 Standard Atlas
1980 Triumph Dolomite Sprint
1974 Triumph Stag
2003 Subaru Forester
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
powder coated parts
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Dash shell repainted correct flat brown
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Splash shield welded and painted.
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Suspension parts and drums
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Original tank and straps repaired
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Bendix discs blasted and primed. Once painted they will be skimmed. Should be close to minimum thickness when done. NOS ones are Waaay to much!
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Back plates stripped of rust. these were phosphated originally, close to black, like a dark grey. Im probably going to tuftride them as this is a very close match but will stop rusting.
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
More parts, silver this time. Yes, i forgot to remove the j nut  :o ::)
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Despite a lack of updates work is still ongoing - slowly.
My axle restoration is stalled! Once i had the casing out, i stripped it and dumped it in the oxalic acid. Once all the rust was gone i painted it ready for reassembly. just a new suregrip and we are done! Or so i thought!
When i checked the gears originally they were 3.23, but on closer examination they pinion is stamped 3.23 ans 3.55 with corresponding part numbers!!! They are actually 3.55.
The current plan is to convert to 3.23, The build sheet says 3.23, the gears are 3.55 and stamped for both. The axle is as far as i can tell, original. What to do??? What is correct?
The axle casing is powder coated and the springs have been reassembled.
Meanwhile, took the gearbox to a mate who promptly stripped it and gave the case back to me to clean up to as new condition. This is now done ready for reassembly. Nasty old casting, doesn't come up how you would expect.
In a wild fit of excitement, i thought i would sort out some heating parts, namrely the heater box. Not any old heater box, but an A/C heater box!
Ive fully stripped this, de rusted and painted the shell, but that did mean i needed to dsort out my plating station. After a few teething trobles the zinc plating is going ok.
With that done, i reassembled the heater box.
A few pics of some of the progress.
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
Finn
2002 Dodge Ram 5.9L 360
2014 Dodge Dart 2.4L
Did you actually count the teeth on the ring & pinion to get the ratio or are you relying on the stamping?
roger440
I counted the teeth! Ive got a 3.23 set here to to compare it too.
There should be more photos, but im having real difficulty posting them (see thread in car discussion)
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
gearbox case
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
roger440
Zinc plated the fittings. Not sure if that was right?
2017 HSV Maloo
2003 Holden SS Ute
1961 Standard Atlas
1974 Triumph Stag
