Beefing up k-frame
Started by runningman, March 17, 2009, 11:06:37 AM
runningman
I was looking at the firm feel site and noticed they sell a k-frame that has some areas that have been strengthened.  Has anyone done this?  What areas need to be worked on?  Skid plate necessary?
Matt
62 Max
My personal opinion is that it is just another part to market,The manufacturers original part seemed to be good enough for millions of vehicles for a hundred years.Other opinions may vary,but thats mine.
Yeah, they're good for millions of vehicles.  But not for a hundred years.
The orignals are showing up with cracks/tears at the LCA mounting tube on the more worn-out examples.  The LCA mounting tube has completely torn out (of the sidewall of the K-frame's rear leg) on a couple of worn examples that I've seen.  (And this is not just a rust issue; one of them was on a texas car with totally solid framerails.)
The steering box mount also flexes a good 1/4" side to side on a lot of cars.  Just inadequate attachment (and sloppy welds) of the mount area on the factory K-frame.  That translates directly to slop in the feel of the steering.
The70RT
Probably depends on how the vehicle is driven or gonna be driven. Mine was used for just 80K and looked fine. If you have a knack for abusive driving or a hard time keeping it between the ditches you could have a problem. I would keep the skid plate on. Entering parking lots and hitting those dips  :P. The factory just spot welded the seams. Some are welding a bead all the way around the seams.  :2thumbs:
62 Max
Quote from: Mike DC (formerly miked) on March 17, 2009, 12:51:03 PM
The originals are showing up with cracks/tears at the LCA mounting tube on the more worn-out examples.  The LCA mounting tube has completely torn out (of the sidewall of the K-frame's rear leg) on a couple of worn examples that I've seen.  (And this is not just a rust issue; one of them was on a texas car with totally solid framerails.)
Based on quantity,still  a "very" small percent if even measurable..Nothing lasts forever.
runningman
I am going to replace my K-frame that is damaged with a different one so it wouldn't hurt to touch up the welds.  I don't currently have a skid plate.  I was thinking that putting one on the new one would help the rigidity of the k-frame somewhat as well.
Hey there's a great article in Mopar Action covering all of this (April 09) it shows you what they do and why! If you want I'll copy it and mail it to ya! Just PM me....Neal (they have 3 issues covering all the steering but the K frame is in April) :2thumbs:
70daytonaclone
can you send this story to me as well? thanks Stephen amxersize68@hotmail.com
Charger-Bodie
I usually just look them over REALLY close , and reweld anything that looks ify . Then Blast it ,paint it ,and go.
runningman
I got a kit from Firm Feel to reinforce my k-frame.  The kit came with a skid plate, will I have any issues with an aftermarket sway bar if I add this??  Thanks
Matt
Hey Matt I was just thinking about your project, my MoPar Chassis book shows how to check and adjust the idler arm angle like we were talking about earlier maybe pick one up and check it out...sway bar I would "mock up" first. Got photos?  :scratchchin:
Foreman72
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
runningman
Quote from: b5blue on May 23, 2009, 10:23:12 AM
Neal,
Here is a link to the firm feel site, you will find a pick of the skid plate on there.  I will look for one of those books, do you have a source for it?  I am gonna be out of town until tomorrow afternoon so I will check back in then.  Thanks
Matt
http://www.firmfeel.com/reinfkfram_b.htm
Think Mancini had mine for 10 bucks (P5007160) (9th Edition)  :2thumbs:
autoxcuda
If you have a K-member that not rusted out or beat up, a stock one will be fine for a stock type chassis build and stock size tires. I'd agree with 62 Max.
IF you've got some handling mods like big T-bars, wide low profile tires, shocks, brakes, sway bars,...
I did this in 1998
I have a picture of the cardboard mockup that is easier to see.
Fall Fling 25
Special 25th Anniversary show!
October 24, 2020
Irwindale Dragstrip, Irwindale  CA
www.cpwclub.com
show cars, swap, drags !
I was just wondering if anyone ever "beefs up" the subframe area also?  :scratchchin: (Around where the K frame mounts)
