distributor
Started by abramsbarry, March 08, 2009, 11:30:29 PM
abramsbarry
got a new distributor for my 383 but the arrow on the shaft (gear?) reluctor shows clockwise rotation will this still work?
maxwellwedge
abramsbarry
i guess the reason i asked this was because the intake casting shows distributor rotation as being counter-clockwise
GreenMachine
That same reluctor is used on small blocks and big blocks. it is installed (clocked) on the shaft a certain way depending on the engine. I have an instruction sheet filed away that shows proper clocking if you need it.
The interchangeable reluctors that I've seen have two keyways and a left-right arrow, if the arrow shows only one direction it might be aftermarket.  :shruggy:
