14 inch drum to disc conversion
Started by Bad 69 Charger, March 05, 2009, 09:45:16 AM
Bad 69 Charger
Ok guysi have searched and cannot find any info on this, i have asked this before and cannot get a straight answer, so if it is on the sight im sorry, i am converting to 14 inch disc or trying, i don't have stock wheels, have heard if i get diplomat, aspen, spindles caliper bracket, calipers it might work, others said to get f-body duster spindles etc, some said cordoba 14 inch setups, the kits that you see on ebay are for 15 but someone said they will work but not with stock 14 inch wheels but aftermarket wheels will work, some said they will work only if you grind off a little on the caliper, i just need to know what spindles i need, caliper bracket, calipers, rotors i can get to make this work, im sure this has been done. With this other pieces from the diplomat etc  some said to change the lower ball joint and all of that stuff will work, see the confusion, i don't know what to go get, let me know thanks Ben
To start you off in the right direction, check out Mopar Action website, go to the article "Disco-Tech" and see if that helps.From your question it sounds like you may be looking for 11 3/4 rotors not 14, they need 15 inch rims, the smaller rotors (10 inch) will work with 14 inch rims....Good Luck!
Bad 69 Charger
Thanks for the info, found a lot of info, here is a link to the story if anyone else wants to know, Ben
http://www.moparaction.com/Tech/archive/disc-main.html
Just so you know there is more info here also, the 73-76 spindle is now hard to find in junkyards. Use the search to see what others have done and the pros and cons of all of it before you buy anything. There are tons of options, even adapters that let you use Viper calipers! Glad this helped you.
