Clutch pedal won't return on its own
Started by DPL, March 01, 2009, 06:55:25 PM
DPL
Hey everyone,
I am just finishing off my 4 speed conversion on my 69 RT and I figured I had everything done when I got into the car and found the pedal when depressed will not return on its own.  If I bring it back maybe 1/3 of the way it then springs back.
Any suggestions?  I am hoping the clutch itself isn't the issue.
Thanks in advance,
DPL
1968 Charger RT
1969 Charger RT
1968 Super Bee
1970 Super Bee V Code
ITSA426
My kid brother just had some Chinese built clutch assembly in his 66 that he bought at a local discount store.  When he'd step on the pedal, the throughout bearing would actually slip through the fingers on the pressure plate.  He  called Brewer's and got a new clutch. No problem since.
Rolling_Thunder
did you use a diaphram clutch ? if so you must remove the overcenter spring  :2thumbs:
Is there a spring pulling the throwout fork forward?
DPL
Yep, diaphram clutch.
Remove the over center spring and WALLA!
Rolling Thunder - Awesome.  :cheers:
1968 Charger RT
1969 Charger RT
1968 Super Bee
Rolling_Thunder
no problem man - that's what we are here for...        BTW I'm glad to see you survived the removal process   :rofl:
62 Max
If you guys would quit using Chevy clutches you wouldn't have to fix the problems you create! :spank:  :icon_smile_big:
