How do you loosen tension?
Started by jdiesel33, March 01, 2009, 04:00:26 PM
jdiesel33
No perverted answers here please.  :icon_smile_big:
I am trying to remove the A/C and other junk. How do I loosen the tension on the belts in order to remove this stuff? Couldnt find any other threads explaining this. It is a stock 440.
1968 Dodge Charger R/T
PP1,Black Hat, Black Stripes
mauve66
i don't have A/C so i don't know which side the belt connects too (i assume the PS side but here are both sides)
under the alternator will be a bolt but the bracket it goes to has a slide in it, after you LOOSEN the bolts (dont take them out) it will slide towards the fan and loosen the belt
PS side, LOOSEN the bolts if the pump is stuck or painted into the brackets you will see a square hole cut into the pump/bracket, use a 3/8 breaker bar to get the pump to move on the bracket, this will loosen the belt
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
jdiesel33
Thanks mauve. That did the trick. I have the PS side setup. After reading your post and looking at it, that totally made sense.
FLG
I believe the hole on the PS pump is 1/2 not 3/8...though might just be a 3rd gen thing??
adrian1
Quote from: FLG on March 01, 2009, 05:30:18 PM
FLG
The hole on the bracket that you use for adjustment.
mauve66
your probably right but when he put the 3/8 end all the way through it i bet he figured it out, i do believe it is 1/2 though
NEEDS:
body work
total wiring
PW
PDLKS
Tint
trim
alignment
