6 Pack Air Filter
Started by doctorpimp, February 25, 2009, 01:38:36 PM
doctorpimp
OK - I tried a search here on the site... LOL  :brickwall:
Can someone please give me the demensions for the filter element on a 6 pack set-up?
Also, does K&N make a filter to replace that bad-boy, or one that'll work/taller etc??
Thanks  :coolgleamA:
maxwellwedge
Fram CA332 and yes, K&N makes one that replaces the stocker - same size etc. This is assuming you have a Mopar Air Cleaner assembly.
doctorpimp
Thanks!
Know the demensions?
maxwellwedge
It's about this long and about this wide.  ;D
Sorry - I don't have one here (office) to measure.
doctorpimp
doctorpimp
Here's what K&N cross-ref went to:
Height: 2 in (51 mm)
Inner Wire: No
Inside Length: 17.75 in (451 mm)
Inside Width: 13.75 in (349 mm)
Outside Length: 19.75 in (502 mm)
Outside Width: 15.75 in (400 mm)
Sound right?
62 Max
Quote from: maxwellwedge on February 25, 2009, 02:50:22 PM
And the outside diameter is the same even if you push it together front to back and make it round! :scratchchin:
Musicman
I have one at home that I could measure for you, but I won't be back there until Friday or Saturday.
doctorpimp
