High Idle?
Started by jonboy20092009, February 06, 2009, 01:39:59 AM
jonboy20092009
I've noticed my Charger has times when it wants to idle high (1,500 to 2,000 rpms).  Only time it stops is when I shut it off and start it back up.  Started about 2 weeks ago, but doesn't do it everyday.  Its a 318 2bbl all stock except exhaust.  I've changed the plugs, wires, cap, and rotor and still does it.  Any ideas?
62 Max
What you changed wouldn't fix your problem.You either have a vacuum leak or linkage problem.
jonboy20092009
I found out I did have a leak.  Should be all fixed now, thanx.
