tic toc tac
Started by mikes4692003, February 03, 2009, 07:22:54 AM
mikes4692003
how can i tell if my tac is even hooked up on a 69 charger 383
blue wire from the back of the tac should go to the accessory  terminal on the fuse box , gray goes to the minus side of the coil , also around that location there is a gray wire that is for the clock !! which  comes out the harness
