Floor Pan
Started by jdiesel33, January 08, 2009, 02:04:53 PM
jdiesel33
Just received my new floor pans in the mail yesterday.  The driver's side is about 3-4 inches wider than the passenger's. Is that correct?
1968 Dodge Charger R/T
PP1,Black Hat, Black Stripes
jdiesel33
Thanks much. Just checkin'.
AutoRust
Its due to the offset in the tunnel for the driveshaft. It does not hit the center of the rearend, but off to the side.
:cheers:
Nothing to see here folks, its just a Bluesmobile
Yep, the whole factory tunnel (and the entire drivetrain for that matter) is slightly offset to the right in the car.  In front it helps the engine clear the brake MS and steering box better, and in the rear it helps the differential pinion sit to the side of the ring gear.
