So my friends, what are your winter plans for your car?
Started by 1969chargerrtse, December 06, 2008, 05:07:42 PM
greenpigs
Hook my exhaust back up and get it ready to fire up in spring for the first time in about 3 years.
1969 Charger RT
Living Chevy free
suntech
Get the car home (on it´s way now)! Unpack all the parts!!! :D
Drive it for a couple of days, tear it apart, and start sheetmetal and mock up work!!
NYCMille
Well... MR ANGRY is staying "as is" for now... no changes. As for ANGRIER - well... he's getting a blown 6.1 HEMI and Viper T6060 Transmission as well as full cage. Should be interesting...   :rotz:
472 R/T SE
My Challenger's getting a new dash pad, v top color changed & the correct bumblebee stripe.
Charger's getting a new dash wiring harness & heater core.
But it won't be a winter project.  I put everything off till the last minute so I'm thinking spring plans.
Blown70
Quote from: NYCMille on December 07, 2008, 08:15:42 PMAs for ANGRIER - well... he's getting a blown 6.1 HEMI and Viper T6060 Transmission as well as full cage. Should be interesting...   :rotz:
YEAAAAAAAAAAAA  WHAAAAAHOOOOOO    :2thumbs:
Hemidog
Quote from: suntech on December 07, 2008, 07:08:05 PM
Gonna drive it in the snow? Don't dent the doors/fenders!  :D
skip68
 Sub-frame connectors and interior.  :scratchchin:  New carb.  :scratchchin: New distributor.  :scratchchin: sending unit.  :scratchchin: power steering fixed.  :scratchchin:  Some wire replacement.   :scratchchin:  Fix exhaust leak.   :scratchchin:   :brickwall:  Dam, toooo much.  :brickwall:  I've got the subframe connectors (US car tools) so that needs to be done before interior.  I've had thoughts of doing them myself.  :shruggy:   :scratchchin:  If only Santa will bring me a nice little wirefeed.  :2thumbs: :drool5:
suntech
QuoteGonna drive it in the snow? Don't dent the doors/fenders!
Hehe!!! i will drive carfully!!! I´m an old man remember!!!! :D :D
rich4406bbl
Add a rimblow wheel, upgraded factory AM/FM, get the ramcharger hood operating, add the rear valence and machine gun tips, rear spoiler, rallye wheels and detail the front grills and rear tailight bezels.
billssuperbird
Mefirst
Get the S.O.B running, then drive/race it untill something blows up and its back into the garage again....
/Tom
quentin
Got a few more pesky mechanical items to knock out, hopefully on some good weather days before the end of the year.  Then I'm going to get some body work done, with a goal of new paint this Spring.  :paintingpink:
Fingers crossed!
'73 SE, 400, 4 barrel with 3 on the tree
RD
get the roadrunner running and break it in... then start the prep work on the 73 to get the drivetrain installed.
nelson_audet
finish the transformation of my charger into a GENERAL LEE  yeeeee haaaaa
my lee will be done in february!
69 Charger RT 440 4 SPD 4.10 Dana car B5 blue
41husk
Well the 68 is in the body shop getting some new paint.  I pulled the dash pad out of the challenger and I am sending it to just dashes tommorow, sure hope I get it back before spring :shruggy: if so both cars should be looking good for spring cruizing.
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
chargerjy9
for the first time since i have owned it. my 73 is at  home in the garage instead of packed away in storage for the winter. I have been cajoled into entering it to the 2009 Autorama, so now during the winter I will be able to prep it
1973 Dodge Charger SE 400 4 bbl,727, survivor
1977 AMC Pacer original
2011 Dodge charger R/T Max
Dans 68
Lets see...on the '68 add a reverse indicator light, find the short in the dash that has left me gaugeless, install an RTE limiter, change the oil and filter, install the rebuilt brake booster (by Dewey), fix (or rather plug the "cheater" holes) in the recently purchased correct air cleaner assembly (see photo below), have the steering wheel rebuilt (probably by stwheels), switch tires from the fronts of my '73 to the back of the '68 (better stance on both) and install a recently purchased and rebuilt 043 radiator. Oh, and drive the car at least once a week.  :D  If I get 3 of these task done I'll be happy....
On the '73 fix the A/C (much smaller list!) and drive it every other week (the '68 does have the 4-speed, after all....).
You have to love the California weather....
Dan
P.S. If Santa comes through I'll be getting a Brewers Performance modified Hurst Shifter for my Inland handle. http://www.brewersperformance.com/products.asp?id=50 and maybe get that in also.  :2thumbs:
472 R/T SE
Why add the reverse light?  Is it an early production?
Dans 68
Quote from: 472 R/T SE on December 09, 2008, 03:40:35 PM
It was built on December 26, 1967. Are you saying that all 1968 4-speed Chargers did not have reverse indicator lights?
Dan
SFRT
drive the hell out of it
. in between that im going to replace the SS leaf springs with a pair of split monoleafs, finish welding on my torque boxes and finish up the interior. I might get a new steering box as well mines a tiny bit loose feeling.
then in the spring, I have to make a big decision about whether to replace my rear quarterpanels or 'fix' the ones I currently have.
Always Drive Responsibly
Uploaded with ImageShack.us
472 R/T SE
Quote from: Dans 68 on December 09, 2008, 03:48:22 PM
Dan
There was a '68 Charger that was being picked apart and I mentioned it didn't have the reverse light so I questioned the authenticity of it being a real 4 gear, then that Coronet R/T dude that knows a lot mentioned what I thought was a shifter change came with the reverse light.  :shruggy:
I only mentioned something cause I thought you were an original type.
Sorry for the 'jack.
Found the thread:  http://www.dodgecharger.com/forum/index.php/topic,29533.20.html
Quote from: 69CoronetRT on June 12, 2007, 10:10:06 PM
Quote from: 472 R/T SE on June 12, 2007, 07:15:59 PM
4 gear and A/C, hmmmm?  There's no reverse light on the dash either, another hmmmm?
Didn't the reverse lights appear with the change over to the Hurst shifters? The VIN looks like it would be early enough to have the Inland....
Dans 68
Quote from: 472 R/T SE on December 09, 2008, 05:36:48 PM
Dan
I only mentioned something cause I thought you were an original type "dude".
Hmm, did not know that! And yes, I'm kind of an "original" type dude when it comes to the details. I will investigate further. Are there other sources regarding the usage of reverse indicators (anyone? I'll start a new thread on this)? I'm guessing since the Hursts don't have lock outs (like the Inlands) how else would the driver know that they are in reverse (aside from easing the clutch out, that is?  :P )?
Dan
tommymac
So whats engine bleeding? Leaking header bolts? Whats a good remedy,Ive tried a few things,but I still have a few drips.Also front discs and new wheels. mabey!Should we change the oil for winter even though it has low miles,still simi clean.
Chris
This is what mine has been doing so far this winter.
1969chargerrtse
Quote from: tommymac on December 10, 2008, 10:48:45 PM
Brian  (mod ) recommended Permatex Liquid Teflon on the bolts to me.  I used their high temp sealer and it didn't last more than 5 months.  As for changing oil, my thought is the stuff is millions of years old, it won't spoil.  Oil never changes state. Oil will be oil for a million more years.  The only thing that happens to oil is the chemicals that change the thickness from thin to thick wear out.  A buddy of mine went to school for Shell and it explained it to me.
