Started by Ranger Max, December 03, 2008, 05:58:06 PM
Ranger Max
Ranger Max
RD
looking good!! Russ got those rods from me a long time ago i believe lol.. glad you are doing something with them.
aifilaw
brand of your rockers?
specs on the cam?
Did you get the lifters as a kit as well from comp, and how much $?
I am halfway through the process of something quite similar, as far as the style of valvetrain and bore/stroke ratio and block.
'72 B5 Metallic Blue Hardtop
Ranger Max
daytonalo
Nice engine but one question , Comp ratio is only 9.8 with alum heads ? You could have easily gone higher with alum heads no problem don't you think ? Iron 9.8 OK but alum easily higher
aifilaw
With that cam and those heads, I would venture a guess that he could have made his static ratio about 11.5:1 and been able to run premium unleaded... perhaps a little less what with the ethanol addition, drop that about a point and you can pull off 87 octane at Sea Level.
Ranger Max
That's a nice engine build Ranger....should make lots of torque and descent horsepower.  :2thumbs:
The 9.8:1 compression is fine....the Comp hyd roller with it's short 224*@.050 intake duration will trap lots of air in the cylinder at lower engine speeds. That cam is a good match with the 9.8 compression....someone was doing his homework.  :yesnod:
If you were wanting to run a larger cam then the static compression could certainly be increased. It's not all about static compression....the camshaft's intake closing point determines cylinder pressure as much as compression does. Everything needs to be balanced for a strong running combo.  ;)
Ranger Max
lisiecki1
Ranger Max
lisiecki1
It's off a flat 6.....other than that i have no idea
Quote from: Ranger Max on December 09, 2008, 12:33:58 PM
BTW
Can anyone ID the head behind the pistons?
I don't see any combustion chambers on that head so whatever it comes off of will have lots of compression !  :icon_smile_big:
Is it a diesel head ?  :scratchchin:
Runner
do you have 2 intake rockers next to each other in that picture?   where in montana are you?.     im guess a small tractor head of some sort?        looks like a nice motor. should be alot of fun
375instroke
I'd venture to say that it's an overhead cam head, and probably a diesel.  See a spark plug?
Ranger Max
ryan053
It should be a fun engine.  Mine is basiclly the same except i am using the xe275 cam with 1.6 rockers.  Mine made 375hp/401tq at the wheels.  In the spring i am going to bring it to the track to see what it will do.
Ranger Max
General_01
That should run nice.
P.S.-I bought my '71 Superbee from a guy in Great Falls in 1989. Didn't see much of the town though. Flew in at about 9pm and left town about 9:30 headed for home in the car. :icon_smile_big:
1971 Dodge Charger Super Bee
496 stroker
4-speed
Ranger Max
General_01
Actually, I bought it off of a guy named Richard Carlson. No Mike's in this equation. :icon_smile_big:
496 stroker
4-speed
Quote from: Ranger Max on January 15, 2009, 10:10:16 AM
:popcrn:
Got all the parts now....should be done soon.
Right on ! Ok when is "dyno day"  :icon_smile_big:
Ranger Max
Lookin good Max !  :drool5:
You gonna shoot the whole engine...paint the heads/intake ?  :scratchchin:
