Carb Question
Started by a192074m, November 30, 2008, 11:08:15 PM
a192074m
Hey everyone>> Hope you're glad to hear that I'm working on my first project car>> Its a 1973 Charger with a 318>> Thisll be the 1st car Ive ever worked on thats older than me  haha>> I got a question about the Carb.... Ive been looking around for the type it is (through Holley and several others) but nothing so far>> the numbers are: 4324629, R40214, 3086>> Id like some general answers about it if anyone can and itd be awesome if someone has pictures of a complete one from different angles>> thanks
skip68
Welcome to the site.  :cheers:  I'm sure somebody will chime in and help you out.  You should post some pics of your car in the other section.  :yesnod:
a192074m
thanks>> I would put some pictures up but im an idiot and dunno how to shrink the pics to size without distorting it haha>> I should warn you all that the car looks alot worse than it really is>> lots of surface rust but not much cancer rust>> i looked around and people say that the SE isnt really worth the trouble of restoring.. but who says that im restoring it    :scratchchin:
If you like it then it's worth restoring.
mikepmcs
4324629 is a 2bbl carb  for a 318.  It's a Holley 2280 series carb.
R40214 is the manufacturer number.
check this site out for available years that you can get a replacement carb... or to buy a rebuild kit.  example: that 2280 4324629 was available on a 318 truck from 78-87.
http://www.carburetor.ca/carbs/catalog/DodgeTruck/index.html
can't find much on the 3086 except that it is a holley carb according to this carb list
http://www.thecarburetorshop.com/Carbsale.htm
also don't forget holley itself, give their tech line a call and they will answer your questions.
http://www.holley.com/index.asp
Welcome to the site and good luck.
v/r
Mike
a192074m
sweet thanks> another question for all you.... this car i assume hasnt been started in ohhh i say 20 some years> what should be checked out for a 1st startup?  i know the basics such as fluid levels, connections, grounds etc but is there a anything that the charger is known to do/break so i dont overlook it >i would assume the mechanical fuel pump is junk after sitting around for all those yrs...is that rebuildable for a 1st start or just fork out the money for a new one?  thanks
lisiecki1
if it hasn't been started in 20 years the fuel tank and lines are probably junk....i'd go with a cheap mechanical fuel pump and a pickle jar just to start it up.........mine hasn't been started in 7 years and i had to junk the tank and the sending unit....the lines were good....so if you need lines let me know, because they're just taking up space in the shop...........but i'm going resto mod so i don't need that stuff anyway (lines wouldn't flow enough......)
a192074m
nice thanks!>> is there anything in the fuel tank that ill need to do the whole pickle jar rig up?? haha>> do those fuel pumps need to be bleeded or can i just crank the engine to suck the fuel up?  it may sound dumb but again it may be common knowledge that i had no knowledge of haha
lisiecki1
if you're taking the mechanical pump out of the loop then you'll need a cheap mechanical from the auto parts store  and some rubber fuel line....just stick one end in the pickle jar, to the pump, and from the pump to the carb.....the carb itself wont just suck the fuel up, you have to feed it....you can always try to use the mechanical pump first and go with the electric if it doesn't work
a192074m
BROCK
Your mechanical fuel pump isn't rebuildable.  Going through the entire fuel system is smart!
When you do replace the pump:  make sure the pushrod is pushed up (or is this just a big
block thing)
Neet trick for getting her started:  Cut the top out of a (fill in your favorite beverage) can
& put a pinhole in the bottom.  Cover the pinhole with a finger & put gas in the can.  Aim
the hole over the carb's vent tube & remove finger.  This will fill the floatbowl.  Now, if she
is gonna start she will.
Don't forget to check your plugs while you're at it.
Let your music be in transit to the world
lisiecki1
+1 on the above message...but if you use the soda can trick be wary of where all the fuel is going....having not been running in 20 years.....in the event of a backfire it'll make your engine real toasty......
and the pushrod thing is just a big block thing....your 318 should have an eccentric bolted to the front of the timing chain assembly that operates your fuel pump.....
a192074m
I tell you what no manual can tell me the stuff u guys are telling me haha>>ive seen in old 4X4 mags that if an engine hasnt been running in a long time that its a good idea to pull the plugs (mine already has new ones in) and put a small amount of oil in the cylinders to avoid a dry start>> is that a good idea?  :scratchchin:
lisiecki1
absolutely......a little bit of marvel mystery oil wouldn't hurt either.....
flyinlow
Never hurts to have a fire extinghisher around when working with an old carb (or new one).
I have a 73 SE 318 ,car,put 446 in. I like the car, its worth restoring ,scratch that,hot rodding to me!
129,000 made, lots of parts on ebay, less $ than 2nd gen. , disk brakes, electronic ignition already. If you like the car,do it.
idahogrumpy
I have a 73 Charger SE Brougham. Mine was a 400 hp 4 speed car. It now has a 440 automatic with a 4:56 Dana 60. This hobby will cost you a bunch of money that you may or may not ever get back! Just enjoy it!!!! Kyle
Too much to say
Too much to do
Too tired to get it done
Too stubborn to give up
GRUMPY
Modified 73 440 Charger, 03 Intrepid SXT, 02 Neon and 2001 Ram 1500 .
a192074m
lol yeh thats true man>> Im kinda like a pack rat tho so if i make it mine then ill never have plans to get rid of it
Quote from: idahogrumpy on December 02, 2008, 11:48:31 PMThis hobby will cost you a bunch of money that you may or may not ever get back! Just enjoy it!!!! Kyle
Wait a minute.  Are you implying that some people get the money back that they put into their cars?  You think I'm one of those turnip truck guys don't you?
