727 trans doing it's Exxon Valdez imitation
Started by timinator, November 19, 2008, 02:39:57 PM
timinator
I installed a rebuilt 727 recently and it's developed a serious leak that's coming thru the dust cover. When I start the car, it immediately starts to puddle oil underneath. I'm just curious if this could possibly be due to the torque convertor not being seated all the way. I went from the stock one to a TCI when I installed it. I've seen shims available that supposedly space the convertor from the flex plate. Is this a possibility to leak if the convertor isn't seated all the way? I'm hoping to avoid pulling the trans to have the pump oil seal inspected/replaced.
idahogrumpy
I would guess that the pump has damage to the bushing that supports the converter. Probably need to pull the trans and have a looksy.  :Twocents: Kyle
Too much to say
Too much to do
Too tired to get it done
Too stubborn to give up
GRUMPY
Modified 73 440 Charger, 03 Intrepid SXT, 02 Neon and 2001 Ram 1500 .
flyinlow
Seal damage or pump bushing . if its leaking out of the bellhousing while running, your  going to have to pull the trans.
