tranny fluid change
Started by rudyjrusa, November 17, 2008, 07:39:45 AM
rudyjrusa
changed the fluid and filter on my 727 tranny.  I started car and went to place shifter into reverse and car does not move in reverse - i have to really step on the gas to get car to move.  when i use to place car into gear it would move without stepping on gas all the way.  the tranny was find before i changed the fluid and filter - what is going on???  anybody have this happen to them??
flyinlow
Set parking brake,idle in neutral,check fluid level, do not over fill.
Torque converter fills in neutral or drive, not in park.
May take a few minutes if you drained the converter.
Years ago I changed the fluid on my parents Plymouth wagon. Same thing would not move. Panicked. After a few minutes and making sure trans was full it worked fine.
Charger72SE
I had the same problem, then read that you have to put car in neutral to get tranny fluid moved around.  Now I start the car, put it in neutral for 10 seconds and then reverse and it works fine.
rudyjrusa
thanks for the info.
i will try it this weekend.
