A little trivia....
Started by Bob, October 27, 2008, 06:26:22 AM
Bob
True scenario....
Transmission swap, (slapstick swap) for Tom.
1971 440 with a 727 attached.
Sold engine to Tom. Kept 727.
Removed my 727 from my 1974, 400.
Installed 1971, 727.
Ok, here it is.....why did I have to remove the 1971, 727 transmission from my 1974 Charger?
And what did I do to correct the problem?
Bob
hemigeno
Were the Torque Converters different between those years (externally balanced)?
:shruggy:
Bob
Quote from: hemigeno on October 27, 2008, 08:00:47 AM
:shruggy:
Bingo Hemigeno . Flex plate to torque converter did not line up, internally balanced verses external.
Luckily I only had to tilt it down and swap them. The shift and kick down arms had to be swapped also.
Besides you, there were a couple others I thought would pick up on it right away.
Age increases, memory decreases. :smilielol:
Bob
http://books.google.com/books?id=6JIHWWW5AS8C&pg=PA33&lpg=PA33&dq=mopar+engines+ballancing&source=web&ots=6RYZ-D1RvU&sig=iDbJUPcg648tlX720u5FbromuL0&hl=en&sa=X&oi=book_result&resnum=4&ct=result#PPA32,M1
dpm68
QuoteAge increases, memory decreases. smilielol
Oh yeah, I forgot about that...
moparstuart
good thing it didnt bolt up because it could have caused you some serious balancing problems
Bob
Quote from: moparstuart on October 27, 2008, 09:43:36 AM
:iagree:
Serious is not the word for it.
hemigeno
Quote from: Bob on October 27, 2008, 08:07:35 AM
:shruggy:
Bob
Looks like I guessed right...   :lol:
Glad you didn't tear anything up, Bob!
