Trunk weatherstrip
Started by bearbqd, September 29, 2008, 08:42:56 PM
bearbqd
Another question for ya... my 68 CHarger has pretty new looking weatherstrip in the trunk, but it still allows a good bit of water in the trunk when it rains and especially after I wash it. What's the best way to remedy this?  Should I put a chalk line around the edge and see where it isn't sealing or should I just go ahead and try another seal?
73 Cuda 440/500hp
71 Javelin in progress
y3chargerrt
Does your Charger have a vinyl top?
bearbqd
It's supposed to, but it currently doesn't have one.
73 Cuda 440/500hp
Hemidog
Might be leaking through the bottom of your rear window
charger2fast4u
i would look at the rear window channel my charger had holes in it and let water run right into my trunk.
charger Downunder
To find the leak get in the trunk with a torch have the wife close it and hose the outside till you can see where the water is coming in.
Once you have spotted the leak good luck getting out.
[/quote]
mikepmcs
I suggest a flashlight and not a torch.  :cheers:
But I agree, get in the trunk and try to pinpoint it.
Also make sure the trunk weatherstrip is positioned in the correct location....supposed to rest on the inner rail of the trunk not IN the drain trough...DAMHIK :rotz:
charger Downunder
Quote from: mikepmcs on October 07, 2008, 06:39:39 AM
This is how it is downunder
flashlight we call a torch, trunk we call a boot,hood we call a bonet.
[/quote]
towscum
what do you call an easy girl?
1969 dodge charger 440 4 speed
C500
Quote from: charger Downunder on October 08, 2008, 04:45:38 AM
and what we call a fanny is something only a woman has
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
tatrick2me
I bought a new 69 R/T SE and the first time it rained the trunk filled up with water. Seems the factory didn't see the need to seal the clip holes for the vynel top  quater panel trim. But today most leaks come from the bottom of the rear glass. The window channel gets rust pin holes in  it.
If any 68 to 70 B body hasn't rusted up out of the channel yet. The best way to fix it is to remove the trim clean the oiutside and inside of the channel. Then brush por 15 with an artist brush in the channel and inside or the trunk. After that work very careful and line the bottom of the channel with fiberglass. Be sure to keep it low enough to be hidden by the trim. In 1977 I ran the fiberclass half way up each side and across the bottom of the channelk in my 69 R/T SE. And its still solid and leak free today.
Bone 7
Quote from: Kiwi68 on October 18, 2008, 07:49:00 PM
Gives a whole new meaning to "fanny pack".
bearbqd
Thanks for the tips. I determined it is leaking from the rear window trim area. It's pretty gay that the factory didn't take care of that area better.
73 Cuda 440/500hp
They didn't plan on us still driving these things 40 years later.  You're right though, leaks back there are a killer and not that uncommon.
tatrick2me
3M weather strip adhesive will also fill up the holes. But a rust converter in the channel and inside the trunk under the channel is very important. If you don't stop the rust in 3 months it will be leaking again.
Bone 7
kevin383
I'm cracking up here......I've heard torch for flash light, but never in a get inside a trunk sentence....hahaha :smilielol:
Car's got a lot of pickup. It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
