68 charger front wheels back spacing , 18x8
Started by dodgey68, September 15, 2008, 12:55:35 AM
dodgey68
hi guys
i am about to purchase 18x8 fronts and 19x10 rears,  intro penita, my question is (if some one can help) as my front end is not together for measurements , can some please tell me what back spacing i would need for the front rims in an 18x8 rim,
the rear is in and i have all the measurements (backspacing)
thank you for your help
when all you own is a hammer, every job  resembles a nail.
metallicareload99
I went with 18" X 8" with 4.5" back spacing.  They fit almost perfect, with enough clearance between the fender and tire, but the upper control arm gets pretty close to the rim/tire when the suspension is fully extended and turned hard over.  I don't think it rubs at all anywhere though.  I suppose if I was going to do it over again 4.25" back spacing would be perfect.  Disclaimer:  I would put some of the front suspension together and measure before putting down the money on what must be custom wheels.  Good luck
Hemidog
metallicareload99, I like your car, think you mentioned it was your daily driver?
Would like to see some more pics of that car...
metallicareload99
Quote from: Hemidog on September 17, 2008, 11:44:33 AM
Thanks a lot Hemidog, it is indeed my daily driver!  I'm really pleased with the wheels, I think they really add to the look of the 1968 Charger, even if mine isn't the nicest example.  If I recall correctly you had some 20" wheels on your Charger?  I thought about going that big on the rears, but didn't think that I could pull it off.  I have a few more pics here, but most are old and they are poorly organized
http://www.cardomain.com/ride/505178
Finn
2002 Dodge Ram 5.9L 360
2014 Dodge Dart 2.4L
Rubberduck
@metallicareload99
This looks wild - I like it
Mario
´68 Charger, 505 by CWE, 4-speed
68charger440
DODGEY68... I know this is very old thread, but curious if you ever put on the 18" x 8 front and 19" x 10 rear wheels?  I am thinking of same combo and would like to see them on a 2nd gen charger.
When someone is absolutely 100% sure they know exactly what your problem is and how to fix it, it's time to ask someone else!
dodgey68
the rears were 19x10, 5" bs, and fronts 18x8 4.5 bs,,
68charger440
Quote from: dodgey68 on July 11, 2015, 10:04:52 PM
thanks...do you happen to have any pics with them on the charger.  As they say a picture is worth a thousand words.  I am looking to get as close to the outside of the wheel well without rubbing and very little space above the tire showing from a straight on side view.  I have seen them on different cars, but it is not the same thing as seeing them on your exact make and model.
dodgey68
I have removed the inside fender wall thingy in the rear tubs also , the front used to rub a little with a passenger but I lifted it a little and now bugger all if none front tyre rub either
and once the 295's wear out I have a set of 305 ready to go on
1974dodgecharger
Quote from: dodgey68 on July 19, 2015, 03:12:38 AM
damn DODGEY that's one badass PIC man I saw your pic on JEGS, but man this one is KILLER!!!
Always loved your setup.....
68charger440
That does sit real pretty like that!  How hard was it to remove that thingy in the tub,
and how hard was it to patch?
dodgey68
Quote from: 1974dodgecharger on July 19, 2015, 06:12:00 AM
i put a vote in  for yours
1974dodgecharger
Quote from: dodgey68 on July 20, 2015, 12:38:18 AM
wow, thx  :2thumbs:
