Headlights
Started by My68Charger, September 02, 2008, 04:32:46 PM
My68Charger
for some reason my headlight on my 68 are not working, I have replaced the dimmer switch but the lights still will not turn on. I have working brake, turn, tail lights. The doors in the grill work just fine but no lights.  :brickwall: :brickwall: :brickwall:
How's the connection of your forward light harness connector behind the battery?
My68Charger
Its in good shape, it could use a little clean up but the conection is solid.
My68Charger
Ok, so I cleaned up the connections and I now have High Beams but no low beams? I have replaced the floor switch so I know that is new... Could I have a bad ground to the switch so its not letting the low beams work?
AKcharger
I've had tons of probles with bad grounds...corrosion sneaks up in those areas over time...what almost 40 years!
bakerhillpins
Quote from: AKcharger on September 22, 2008, 12:54:54 AM
:iagree:
My bike is 12 yrs old and the electrical system is something that needs monitoring.
Bryan
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
