1969 new yorker 440 engine
Started by darkside, August 17, 2008, 03:20:59 PM
darkside
i found a 1969 new yorker with a 440 4bbl  engine in  it that i'm  thinking of buying to build and i was wondering if
someone could give me the info on  the motor like the   stock  compression, heads and stock hp that came from the factory on this engine?
If i remember right it should be a  factory 350 hp rating engine right? thanks
i'm thinking  all the difference  between that & a the 69 hp motor  is  the cam & windage tray  & oviously  b- body hp cast iron manifolds  .. it has 906 heads  & the same intake as the  hp motor also ....  :popcrn:
darkside
does it have the same size valves as the hp heads?
Challenger340
Only Basic differences between your 440 and the H.P. version is Camshaft, Valve Springs, Windage Tray, Some Jets & metering Rods, and the Exhaust Manifolds.
Good score.
Is it original and un-rebuilt ?
Only wimps wear Bowties !
darkside
yes the motor is originial and in the car ,going to pick it up in a few days,
I believe the pistons were also different between the 375hp version and the 350hp engines. Compression was usually closer to 9:1 on the std 440 350hp motor as well while the Magnum/Commando/TNT engines were closer to 10:1
Good score !  :2thumbs:
Musicman
 :iagree: Good block.. lots of potential  :2thumbs:
