still hot
Started by onebadmopar, July 20, 2008, 10:47:37 AM
onebadmopar
im still running hot according to the gauge electric aftermarket it gets up to around 230 on electric gauge aftermarket when i just it down it spits out the overflow tube just a little more like a drip i dont hear any gurgling coming from  radiator at all i would think at 230 it should be spewing all over or am i wrong? i just dont want to blow up this motor it dont even have 200 miles on it yet
craigandlynda
be sure you are running 50-50 antifreeze and water....the antifreeze also acts as an anti-boil, raising the boiling point past 212.... :Twocents:
Get an inrared heat gun and measure the temps. Compare the numbers between the upper and lower hoses....there should be a 30* difference between the inlet and outlet. If not...the rad is plugged or doesn't have enough cooling capacity.
It's also possible you have an air pocket in the cooling system or a stuck thermostat. Get the car up on ramps and start it up with the rad cap off and leave it like that until the coolant starts circulating. Keep an eye open for bubbles in the coolant. Air pockets often form at the back of the engine and will not bleed out....raising the front end forces the air pocket forward into the rad and out when the cap is off. By doing this you are effectively "burping" the cooling system.
onebadmopar
both radiator and thermostat are brand new so a clog isnt likely altho i havnt tried burping it as you say but im gonna try that virtually everything under the hood of this car is brand new motor has maybe 200 miles on it now  new water pump hoses etc etc
onebadmopar
raised up the car like you said started it up took cap off .... lots of bubbles .........it flows really good  keep ya posted on wether this helped i think for sure im gonna get the vicious fan and a shroud too im running a straight fan now no shroud but i can feel the air coming thru the radiator pretty good
1969chargerrtse
Quote from: onebadmopar on July 20, 2008, 04:45:04 PM
My rebuilt 440 runs nice and cool when it's cool out but the heat creeps up as the day temp rises.  I have the Mopar flex fan kit and shroud also.  I believe  these cars run on the hot side generally anyway from people i've talked to.   New motors run hot also, give er some time to break in, I can tell a difference now that the motor has about 1,800 miles on it.
