Is there a difference between '69 & '70 Doorshells??
Started by Dan T, June 11, 2008, 11:29:05 PM
Dan T
I know the inner panel is different, but is there anything else different between '69 & '70 doors?
Mine is pretty banged up, and someone has a solid '70 door, but I want to make sure that there are no small differences..
1969 Charger R/T
1969 Dart Custom
2006 Charger R/T
Charger1973
Im not a 2nd gen guy but I have been around them a bit and im pretty sure they are the same.
JimShine
Other than the R/T doors having the scoop holes, the only other small difference I notice is the 1970 has a smaller hole for the door lock stem. I am assuming it was to standardize all the Charger doors so the base line model could have the simple ferrule rather than the pad. I do believe the 1969 pad will still work. They just eliminated the need for the larger hole allowing a big tolerance in the upper door pad lock stem placement.
