Removing Spark Plugs
Started by jdiesel33, June 07, 2008, 12:53:38 PM
jdiesel33
Hey Guys, In a 68 R/T 440, do you have to take the exhaust manifolds off to change out spark plugs or just have the right kind of tools to get to those hard to reach plugs?
1968 Dodge Charger R/T
PP1,Black Hat, Black Stripes
You just need the right combination of extensions, swivels and swear words.  They'll come, keep trying.
jdiesel33
In that case, at this point  :icon_smile_dissapprove:all I need is the right combination of extensions swivels!
I typically use a plug socket with a short (3 inch) extension and a ratchet with a pivoting head.  By swivel I mean one of those universal joint extensions.  If you are just using a standard socket set you should still be able to come up with a combination that gains access.
chargerman68
Quote from: Ghoste on June 07, 2008, 12:56:31 PM
thats for sure...
wait till you get headers :brickwall:
myk
Spark plug removal on the 440's nothing.  Try doing it on an LT-1 or LS-1 and you'll soon know real pain...
oldschool
on the hard ones to get at,i use a plug socket with a hex head.
i then use a shorty wrench on the hex head of the socket.
have not found a plug i could not get to with this combo.
hope this helps. :drive:
1970 Charger 580" 4-sp
Quote from: oldschool on June 08, 2008, 08:10:20 AM
  yep  :iagree:    also  number 1 & 2 plug  are  the only ones i do from the top  !  all the rest from the bottom  much easier , well for me any way  :Twocents:
