Transmission link to speedo cable has crossed threads
Started by AmadeusCharger500, June 01, 2008, 08:07:30 PM
AmadeusCharger500
Trans is leaking at speedo cable. I bought new cable but when I tried installing it I found the threads where totallly cockeyed. I put it on anyway and of course, it still leaks!
Is this detachable from the trans and if so does anyone know how I can get it?
Charger-Bodie
the cable shouldnt be expected to seal it.
There are 2 o-rings in the speedo gear housing , a big one around the housing and a small one that seals where the post of the speedo gear comes through.
tecmopar
Thats correct, you can run it with out the cable attached and it should not leak. You need to change the seals in the speedo gear housing or grab another one, pretty easy to find though so it won't be to bad, good luck.
