light problem
Started by 68bigblock, May 29, 2008, 07:17:47 AM
68bigblock
:'(   I just found out last night on my 68 charger r/t  that  I  got wiring issues. Went to check the lights and I have ... headlights, taillights,brakelights, turn signal lights ... But no dash lights, Just the right turn signal  light.  And the only gauge that works is the alt .   I need a wiring diagram.   Help!!! :RantExplode:
71_deputy
1971 Deputy Challenger 383 4bbl-- 1 of 2 made!!
1967 Charger 440/auto
1973 Road Runner 340/4 speed
2000 1500 Ram Van
68bigblock
Thanks      71_deputy .    I will .  :cheers: :2thumbs:
tommymac
It could be the dimmer or bulbs mabey?
68bigblock
Thanks  tommymac ,  while I checking the wiring I will check the bulbs and the dimmer.   :2thumbs:
mikepmcs
yeah, don't the dimmers get dirty/corroded or something and that will cause said problem.(translated to mean.... this is a common problem)
keep it simple first before going and tearing everything apart.  Like was said, could be a simple combination of a dirty dimmer switch and some burned out bulbs.
Welcome to the site. :cheers:
v/r
Mike
68bigblock
To late, I've taken the dash apart. Good thing too, looks like someone in the past spliced into a couple of wires for other things.  :RantExplode:  But I will check out the dimmer.  Thanks mikepmcs   :cheers:
