cam question
Started by hazzard1976, May 07, 2008, 08:13:56 PM
hazzard1976
I have a 509.mp, cam. 2,800 stall, with a 440. 355 gears. I am changing cams to a edelbrock7194 http://store.summitracing.com/partdetail.asp?part=EDL%2D7194&autoview=sku  Im looking for good take off power while not idleing me out of the seat. Its like a harley right now. Want it smoother but dont want to change the tourgue converter
Do you think this is the right move?. I have a rpm preformer intake 750 demon carb.
RD
Advertised Intake Duration: 300
Advertised Exhaust Duration: 308
that cam is bigger than the one you have... it will be about the same...
go for a mopar purple 274 cam, or Ron can suggest the engle brand (dont know them that well)... that should do you fine.  and dont worry about the converter.. it will live and perform fine with that.
Like RD says (correctly) the Edelbrock cam you're looking at has as much or more seat to seat timing as the MP 292.....which means it will idle and behave almost identically.  :eek2:
With the 3.55's and 2800 stall you want something more modest and with descent street manners. A couple of choices to look at are the Engle K56 or the 268 VooDoo cam. Either will drop right in without swapping valvesprings, rockers etc....and will be a huge improvement in bottom end power.  :2thumbs:
hazzard1976
Quote from: firefighter3931 on May 08, 2008, 08:33:52 AM
So what duration do you think there are several?
Quote from: hazzard1976 on May 08, 2008, 09:59:14 AM
The 60303 VooDoo would be a nice choice :
http://store.summitracing.com/partdetail.asp?part=LUN%2D60303LK&autoview=sku
The K56HYD Engle would also work :
http://englecams.com/catalog/search_results.php
hazzard1976
The voodoo looks good but I have a single bolt cam sprocket :icon_smile_question:
Quote from: hazzard1976 on May 08, 2008, 10:16:46 AM
You could allways buy a new timing chain set.  ;)
OR
Order up the K56 Engle stick which has a single bolt upper gear.  :yesnod:
There won't be much if any difference between these cams....if your timing chain is in good shape (no slack) and you feel comfortable re-using it then order the Engle cam.  :Twocents:
hazzard1976
Well I called engle and they recomended the k58 cam. So i should get it tommorow. I hope it works well for me.
Thanks Yall
Adam.
RD
H K-58HYD .520"
.520" 276°
276° .347"
.347" 230°
230° 110
will your springs handle the lift?  not sure what they are rated for as far as spring pressure, but the .520 is .011 higher than you .509 cam right now kapeche?
Musicman
I would have stayed with either one of Ron's recommendations  :scratchchin:
hazzard1976
I called, and Chris at engles said the web site is a misprint and that its not a 520 but a 513
Adam
RD
did they ask you any questions regarding the type of springs you have on your heads currently?
hazzard1976
No but he ask what cam im currentley using, I told him mp 509. and he said my springs would be fine.
You think Im ok?
Adam
RD
Quote from: hazzard1976 on May 08, 2008, 08:08:03 PM
You think Im ok?
Adam
merciful minerva batman!!!!  IMO, its okay to say such stuff if you are going a tad smaller, but never bigger.  Your springs may be spec'd out to go to a specific spring load pressure without the worry of coil bind, but if you dont know what you got, then how can the yahoo make such a suggestion... wowsers.. pm Ron about this, he is more of a guru regarding spring pressures, loads, unsprung weight blah blah blah blah and see what he says.. it may be okay, but Ron would know.
hazzard1976
Called the machine shop this morning and he said these are the springs he put on my heads, Said they would be good all the way up to 539.
Adam
http://store.summitracing.com/partdetail.asp?autofilter=1&part=LUN%2D73815&N=700+115&autoview=sku
RD
ahhhh.. the comfort of reassurance :D
Quote from: hazzard1976 on May 09, 2008, 07:58:34 AM
Adam
Those springs are fine with the K58...you're good to go  :2thumbs:
hazzard1976
Thanks Yall
Ill let you know how it does
Adam
Quote from: RD on May 07, 2008, 09:31:21 PM
274 ? don't you mean 474 ?
Mopar Crazy
Do it Once and Do it Right !!!
