Which Heads?
Started by doctorpimp, July 26, 2005, 11:44:33 PM
doctorpimp
Which brand of heads would be the best choice for a stroker 400 - Stage VI or Edelbrock?
Or Indy?
What other mods are you planning?
doctorpimp
I don't want to spend a fortune on heads, but I want a good aluminum, streetable head for a 499 ci B eng.  80-88cc chambers, for about 11:1 compression
I want to use commonly avail int manifolds etc.
I would use Bulldogs or stage 6 , the advantage of using stage 6 is you can use the bigger 440 intake which really helps feed the engine
It depends on how much power you want to make. If 600hp is enough, the Edelbrock's will get the job done. More than that will require a better head, bigger intake and carb. The Indy ez-1's with a max wedge intake port and matching manifold would be my choice for a build of that magnitude.
71 Pro Street
