Rear End
Started by Blacknight, April 22, 2008, 02:44:34 PM
Blacknight
I just got my headers and three inch exhaust installed. I just found out the rearend is a 7 1/4. I want to get a 8 3/4 rearend with posi not sure on what gear ratio i should go. I am trying to build a street strip car. Can anyone recommend a gear ratio and were  i can get a complete 3rd member 8 /34. Thanks
myk
You can always go and buy 'diff stuff online from vendors, or scour the junkyards.  I believe there's a post in here about identifying the various 'diffs and whatnot.  Keep in mind though, that gear ratios need to be coordinated with the 'cam profile and torque convertor also.  Failure to do that will give you a dog of a car like mine!
The Kid
It depends. We'd need more info about your setup to properly reccomend the right gear. Also, whether you want to be able to cruise at 60mph+ on the freeway is also a deciding factor.
Generally, if you still want to be able to cruise on the highway you'd be probably better suited with a 3.55 gear set. However, if your crusing the street you'd be able to get away with 3.91's or even 4.10's.
Like I said, more info is needed.
mikesbbody
great advice from myke, and the kid. I have 3.55's I have driven cars with 3.23's or 2.9's and they feel slow. I do very little highway driving i have a set of 3.9's and a spare 8.3/4 limited slip but i dont know if i will use that over the 3.55's
