Trunk Floor Replacement (Updated/Complete 1-28-2010)
Started by TexasStroker, April 17, 2008, 12:41:46 AM
TexasStroker
Hey Everyone...Just signed up a few minutes ago and kind of getting a feel for the board and layout..Liking it so far, but then again how can you go wrong with a Charger forum  :icon_smile_big:
I hate taking up other people's time, but I have skimmed the "trunk floor replacement" and "trunk floor" offerings with the search feature...Not coming up with what I am looking for.  So my first question is if there is a complete and thorough thread detailing trunk floor removal and install on a 69 Charger that someone remembers and has the link too...post the link and I'll go from there.
Similarly, has anyone compiled measurements for all the brackets and mounts in the trunk?  (Yes, I did measure, not that much of a rookie!)  Just curious here...
Obviously I am in the middle of replacing the trunk pan on a 69 Charger.  I am a rookie when it comes to body work and have all sorts of questions to entertain and maybe amuse (rookie body work status).
I guess I'll dive in with a few as opinions or experience may have changed (and I don't often see these brought up):
1.  My pan is pretty much shot, the extensions are good and the upper trunk floor (above the rear axle) is still solid and should look good with a clean-up.  Is it best to cut this at the drop, just before the shock crossmember, or what?  I have the 2 piece replacement btw.
If so, do you place the new pans in over this section and spot weld it or do you cut the pans and weld them at an overlap?
2.  I have been asking around with virtually no luck on this one:  Do you cut around the bumper mounting bracket (wedge piece spot welded to tail panel that bolts to bracket that bolts to bumper) and trim the new pans around this or do you remove the whole bumper assembly etc?
3.  My pans do not have the 90 degree lip to attatch the back (tail panel end) of the the trunk floor to the valence.  I have been told you fabricate a 1"x1" piece for this.  Does anyone have pics of this or advice on making it work?
Hopefully these aren't redundant questions (if so let me know where they are redundant and I'll gladly soak up that info!).
Thanks in advance for any input/replies  :2thumbs:
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
BigBlockSam
TexasStroker
I will hopefully be able to post up a few pics tonight if it will be of any use...
69*F5*SE
bill440rt
Hi TexasStroker,
Welcome to the 'site!  :wave:
Ahhhhhh... the familiar trunk floor replacement. You could ask the same question to 10 different people & get 10 different answers as to which is the best way.
Well, having said that, here's how I did mine on my '69 Charger. Your trunk floor sounds similar to the shape mine was in.
1) My floor was shot, the driver's side extension was OK, the passenger side extension was shot. The hump above the rear axle was also good on mine. I was able to section the floor in right where the hump goes up, well before the crossmember.
Now, there are two ways of welding it in. You can overlap it as you suggested, that's what I did. It all depends what kind of car you're building & how far you want to take it. If a visible seam under the car is a concern, then you might want to consider butt welding it (the new floor will meet up right next to the old floor, edge to edge). If a seam is not a concern, than overlapping it is fine. I left about an extra 1/2" of the old floor in place, & used a flange tool to create a "step" where the two pieces met. After doing bodywork inside the trunk, the seam was invisible. I smoothed out some seam sealer underneath, you can't see it unless you're flat on your back on a creeper with a drop-light. Done.
2) Remove the bumper from the car. In fact, remove as much as you can from the back of the car, there will be less in the way & less risk of damaging surrounding parts.
For the welded in wedge brackets, I took a cut-off wheel & cut the factory mig welds that hold them to the floor. I then bent them upward out of the way, to get the old trunk floor out & re-install the new trunk floor down at an angle. Once the new trunk floor was welded in, I then bent the wedge brackets back down & re-welded them. That way, they always stayed in the same place. It this does not work for you, then measure their location beforehand & remove them completely.
3) Again, if the way it looks from underneath is not a concern, there is a way around this. The 90 degree lip on my original trunk floor was surprisingly good. So, I cut the old trunk floor out leaving about 1/2" of it intact right at this bent. I simply laid the new trunk floor on top of the lip with the back edge of the new trunk floor butted up against the back of the lip. You can then spot weld or mig weld it in place. A thick bead of seam sealer like the factory did will hide the seam, & you can dress the edge up underneath the car as you wish.
If your original trunk floor lip is shot, then I guess you have no choice but to fab up a new one out of a piece of sheetmetal.
These methods may not work for you if you are building a concours show poodle. However, even for "most" of the show cars out there, this method should be fine. To add fuel to the fire, I partially welded & bonded my trunk floor in, with 3M bonding adhesive. Strong stuff.
Good Luck!  :2thumbs:
PS - If you PM me your email address, I can send you some photos. I know I posted them on here, but it was a while ago.
TexasStroker
Thank you for the reply bill440rt!
I saw you mention that you sectioned yours in the AMD pan thread (I've had my year one pans for about 4 years now...I would kill to have one that has the correct rear mount).
I'm afraid my lip may not be salvageable...The rust was pretty bad right around the latch area...
I will get pics up later tonight...Should give everyone a better understanding of what I'm trying to convey (although you seem to know 100%!).
Awesome on the weld in wedge brackets...I just posted in a ttt thread on another site the idea of cutting the factory tack welds and leaving it spot welded to the tail panel!!!  Good to know you've done that very thing!
As for the show poodle...not me...I drive my cars  :coolgleamA:
I can't do concours anyway, no clue where the numbers matching engine would be...plus I'm partial to the 440  ;D
I will move on to pulling the rear bumper...FWIW my tail panel, valence, and quarters are all good and will be staying on the car...
Believe it or not I had a very well respected resto guy suggest I use the 3M Adhesive for the trunk floor...I'd have given it a shot if I would not have already bought a welder.
Thanks for the welcome to the site and useful information, PM will be sent!
69*F5*SE
Here, search through the pages of this web page and see if it has any info you could use.
http://www.69hemi.com/restoration.html
TexasStroker
Quote from: 69*F5*SE on April 17, 2008, 03:32:10 PM
Thanks for the link...I've hit that site for reference a few times.  I think bill440rt basically knows right where I am at in this predicament.
I'd have pics up by now but I am still at work...Hopefully before midnight, lol!
TexasStroker
Right, so "later tonight" turned into 130AM...Nonetheless, here are some pics:
Jump over rear axle...Pretty solid above where you see the "peppering"
Two shots of the LH side bumper mount wedge:
Latch frame to trunk floor, err used to be anyway:
RH Side bumper mount wedge:
bill440rt
Uhh...   :scratchchin:    ...can't see the pics, dude.  :scope:
TexasStroker
geez...I had them posted, know they worked...
I'm guessing they aren't showing up since I made the mistake of being organized and moved them to a "trunk floor folder."  Just my luck  :brickwall:
I'll host them from their new folder with unbroken links asap!
TexasStroker
Links fixed...too bad the trunk floor isn't that easy  :icon_smile_big:
suntech
That trunk looks pretty much junk!!
What i would have done, if the quarters and extentions are good, ie to take the entire floor out, together with the braces and trunk lock support. Also remove the tail light panel
Then call Auto Metal Direct, and get a one piece trunk floor, braces, lock support and tail light panel. With the tail light panel out, you should be able to slide the one piece trunkfloor in, from the back. Like this you can make it look as it should be, with no extra seems and welds.
bill440rt
T.S.,
Your trunk floor looks very similar to the way mine did. You'll definitely need a new lock support, but the back lip looks salvageable to me. You may have to put in a little patch under that support, but for the most part it looks OK. If you can have the area sandblasted, that would also be good.
Your tail panel looks alright too, from what I can see. Don't remove it if you don't have to. My way of thinking is, do not cut up the car if you don't have to.
I'll be sending you photos shortly.
TexasStroker
Thanks for the input and feel free to keep it coming.  Man, I can only wonder what the lock support is SUPPOSED to look like...Might have to ask for pics or track down one of the guys around here with 68-70s.
My problem with pulling everything out and putting it all back in is the car is sold except for the trunk.  Good paint, driver, etc...
I'll look forward to the pics Bill.  I've got to run and kick some grass, but am going to try and get a good work load in this weekend!
Like I said, keep your suggestions, ideas, and past experiences coming...It'll only help me and anyone else in this boat.
Thanks!
suntech
QuoteI can only wonder what the lock support is SUPPOSED to look like
Download the catalog from Auto Metal Direct website (pdf file), you will see a picture of the trunk lock support at page 10.
69*F5*SE
TexasStroker
Thanks for the links...I found it at Stephens....Diddn't realize downloading the AMD catalog would give me part by part breakdowns like that...I'll try it out tonight.
I did notice on their site that part # 47 on this page: http://www.autometaldirect.com/content.php?page=117
doesn't seem to come up in the schematic.  Is it the piece that bolts to the frame rails with a u-hump and square hole in it?  It may show in the dl catalog...if so I apologize.
Have ya'll found AMD prices/quality to be the best for items like the trunk lock support or are they all about the same?
Also what would the best way to remove the trunk lock support from the car?  Should I use spotweld cutters or try and get a cutoff wheel up under the spotwelded brackets or what?
Does anyone have a direct shot at a newly installed trunk lock?
On mine that area had rust so bad the bottom flange had thinned and the integrity was gone along the lower support seeing how the bottom flange seperated from the suppor to the floor  :'(
Thanks again for all the replies!
69*F5*SE
Spotweld cutter could do it probably.  Use what you got that won't cause more work or damage.
TexasStroker
Quote from: 69*F5*SE on April 19, 2008, 06:17:46 PM
I'll probably save a spot weld cutter to keep it as sharp as possible for that...
Made a little progress today, sort of lost a few hrs to interruptions, but should get in a long day tomorrow...Actually think I'll put in a little more time tonight  :coolgleamA:
TexasStroker
Got the rear bumper off and a little more of the floor out...Also dressed the frame rails up a little bit up top.
I've come up with a few more questions though (bet no one saw that one coming!).
First off, will heating the seam sealer up help it come up easier?  The driver side wasn't too bad, but the passenger side is a beast...they laid it on thick!  I think I've heard of it being done, but I've also read a thread recently where someone cautioned against it due to the fumes.  What is the consensus here, doesn't seem like heating it up quickly would be too big of a deal with ventillation??
Second, do ya'll reccommend using a cut off wheel in between the trunk floor pans and trunk extensions to seperate the peices or should it be cut close and THEN drill out the spot welds?
Last one for the night...As far as the bumper brackets go (the actual pieces that bolt to the bumper and then into the supports tacked to the tail panel and floor) is it easy to get them lined back up?  They are a little rusty and it eats away at me to take something apart and not put it back in the best shape I can...
Thanks in advance for any feedback!
69*F5*SE
Just mildy warm up a small area of seam sealer with a propane torch and see if it'll come up easier for you.  If it does then away you go.  Drill out your spot welds to separate the floor from the extentions. If you have a good spotweld cutter then have at it.  After tearing your trunk floor out you'll have a better understanding of what it takes to work with the rest of the metal on your project. Hope this helps.
TexasStroker
Quote from: 69*F5*SE on April 21, 2008, 06:14:00 AM
Thanks!
I picked up a respirator (the dust masks weren't cutting it for me) and I'll try getting the seam sealer loose with some heat...
I'm going to cut a little closer to the extension-pan joint and see if I can then find the spot welds and drill them out...then finish it off with a straight cut.
TexasStroker
Sorry to keep this hanging so long but I just haven't had the free time to really make significant progress :(
I did heat up the RH side seam sealer...at first I just thought it was going to be a lost cause but it finally came up a bit...Not like butter but it is atleast up...
Also got some detail work done on the inner frame rails...I'm hoping I can get a solid 2 days in on the weekend...
Landmark update...I know  :lol:
TexasStroker
Did have one question come up tonight...The small holes in the bumper support mounts (wedges) are they a factory item or something someone did along the way??  You can see them in both of the previously posted pics.  Anyone know?  :shruggy:
