73 dodge charger front end
Started by dogmank912000, April 14, 2008, 07:11:56 AM
dogmank912000
 can anyone tell me how is the best way to raise the front end with these torsen bars, air shocks. or is there another way.. want the front to set higher.
:shruggy:
FLG
Simple thing to do would just be to crank up the torsion bars a bit
stevekarlo
The t-bars crank up and down fairly easy. But you may need to get a realiangment after you do. And if you get an alignment make sure they align it at that given height. The tech might lower them to the specified height. Also once you raise it up, you need to really get on the fender and bounce the car up and down several times  to get the height set.
dogmank912000
 can anyone tell me where the torsen bar adjustments are on the 73 charger se... :shruggy:
Charger74
Quote from: dogmank912000 on May 05, 2008, 07:55:38 AM
Look under the lca's (lower control arms), you will find a single bolt pointing to the top, that is your adjusting bolt for height.
stevekarlo
To lower just crank it down, If you are lifting you want to take the weight off of the arm, It makes it easier to turn. After turning it though, get on the fender and bounce it up and down several times to get an accurate ride height. Also make sure you turn BOTH sides an equal amount.
