68 headlight doors
Started by moparchris, April 01, 2008, 12:08:04 PM
moparchris
Just finished a 4 year resto on my 68 Hemi Charger and started it for the first time on Sunday.  Problem is: As soon as the motor starts the headlight doors both flip up.  Headlight switch is not on.  Do I have the vacuum line routing wrong?  Three vacuum lines exit the bulkhead, one goes to the vacuum canister and two go to the doors, do I have the wrong hose on the vacuum canister?  The service manual does not specify which hoses go where it only shows a general routing illustration.  Any one got an answer?
70Sbird
Try swapping the vacuum lines on the door actuators. Vacuum opens the door with the dash switch in the on position, and vacuum holds the door shut with the switch off. The actuator has vacuum connections on the front (rod end) and the rear. Just swap positions of those two lines and you will probably solve your problem
Scott Faulkner
resq302
You might have the two lines that connect to the "t" fitting near the rad support reversed.  That is exactly what would happen if they were reversed.  If you turn your headlights on, does the doors go down?
Brian
moparchris
Thanks guys.  I will try this.
